EVGA teases 360mm All-In-One Liquid Cooler
To date, EVGA’s largest Closed-Loop Liquid Cooler (CLC) has been their CLC 280, a 280mm offering that supports dual 140mm fans. At Computex 2019, EVGA has revealed that they plan to go large with their next-generation cooler offerings, revealing their CLC 360 liquid cooler.
As the name implies, EVGA’s CLC 360 is a 360mm liquid cooler which utilises three 120mm fans for cooling. Up to six fans will be supported by this cooler using a push-pull fan configuration. Like EVGA’s existing CLC solutions, the CLC 360 appears to be an Asetek-based design, which means that the cooler is likely to support all of the same CPU sockets at EVGA’s existing cooling lineup.
EVGA hopes to reveal more details about their upcoming CLC 360 CPU cooler in the near future.
You can join the discussion on EVGA’s CLC 360 CPU cooler on the OC3D Forums.
