Formula V Line unveils its stunning Air Power G10 case ahead of Computex
Formula V Line plans to unveil 22 new products at Computex 2026
Formula V Line is hitting Computex 2026 hard, with plans to showcase 22 new products at the event. Headlining the event will be the company’s new Air Power G10 PC case, which it has previewed today. The case features tilt-adjustable intake fans and an ultra-clean aesthetic. With its tilting fans, users can adjust them to perfectly suit their hardware setup.
Formula V Line will preview the Air Power G10, a new mid-tower chassis with tilt-adjustable front intake fan mounts, at Computex 2026. The G10 is the lead product in a 2026 lineup of 22 new products spanning computer cases, air coolers, cooling fans, power supplies, and gaming chairs.
– Formula V Line
The Air Force G10 rethinks PC airflow
With its tiltable fans, users of the Air Power G10 can independently target their airflow to maximise their impact. Each fan has a quick-release and a nylon dust filter, enabling easy cleaning and fan replacement. The case also features a tool-free, removable top panel for installing a liquid-cooling radiator.
This case also features bottom-mounted fans, with its bottom chamber being repositionable to allow PC builders to further tune the case’s airflow.
The Air Power G10 Chassis Rethinks Front Intake
For years, front intake on PC cases has worked one way, with fans fixed flat against the panel. The Air Power G10 breaks from that. Its three front intake fans each sit on an independent tilting bracket, so builders can angle each fan to aim airflow toward the GPU, toward the CPU socket area, or anywhere in between.
Each fan bracket is designed for quick release and includes its own nylon dust filter. Builders can remove a single filter for cleaning or replace any of the three fans with their preferred models. The chassis also features a tool-free removable top panel that simplifies radiator installation.
The Air Power G10 also features an interchangeable bottom chamber module that can be repositioned forward or backward, letting builders tune airflow and thermal layout to match the build requirements.
Full specifications, materials, and clearance details for the Air Power G10 will be available at the booth.
– Formula V Line
Alongside the Air Power 10, Formula V Line plans to showcase new liquid cooling solutions, PC cases, air coolers, new cooling fans, PSUs, and gaming chairs. Full details for these products will be released next week at Computex 2026. 22 new products will be showcased in total. If you enjoy tinkering with your PC case and optimising its thermals, this could be the perfect PC case for you.
Note that full specifications for this new PC case will be available at Computex next week.
Showcase Cases and Cooling Fans with Built-In Displays
Beyond the Air Power G10, the 2026 lineup includes new computer cases built around panoramic glass and showcase airflow, new air cooler series, new cooling fan series including a model with integrated displays, new power supplies, and new gaming chairs. Product naming, full specifications, and launch timing for each will be shared with editors at the booth. Currently shipping models from the Crystal and Air Power case families will also be present for hands-on comparison.
– Formula V Line
Formula V Line will be at Computex 2026 at Booth I0417a, Hall 1, on the ground floor. Expect to see more from Formula V Line next week.
You can join the discussion on Formula V Line’s newest products on the OC3D Forums.
