Fractal Design Releases their Prisma Series of RGB 120/140mm fans
Fractal Design Launches their Prisma Series of RGB 120/140mm fans
RGB components are popular these days; there is no getting around it. RGB sells, and that is why we see RGB lighting hit seemingly every component within the PC market. Now Fractal has jumped onto the RGB train, with new 120mm and 140mm fan offerings, with models that are designed to offer addressable RGB lighting and support for either PWM or non-PWM fan control.
Fractal’s new Prisma fan designs come in 120mm and 140mm variants, offering the same silence-optimised LLS bearings and semi-opaque white fan blades, which are ideal for RGB illumination. These fans are marketed under the Prisma AL (Addressable Lighting) name and support ASUS Aura, MSI Mystic Light, Gigabyte RGB Fusion and ASRock Polychrome Sync RGB control software. These fans can be connected to devices which support 3-pin ARGB outputs, which are common on most of today’s high-end motherboards.
These new Prisma AL series fans are designed to be daisy chained and support Fractal’s R1 series RGB controller, which is available separately. Prisma AL series fans are available both individually and as part of a 3-fan pack. Each of these 120mm fans has seven fan blades and rotational speeds of 1200RPM for the 3-pin version and 500-2000 RPM for the PWM versions. The larger 140mm versions offer slower speeds of 1000 RPM, for the 3-pin version, and between 500 and 1700 RPM for the PWM powered variants.
On the lower-end Fractal has also launched their Prisma SL (Single Light) series of fans, which offer static colour options like red, green, blue and white. These fans are NOT RGB and only provide a single static colour options.
These fans are great for PC builders who only have a single colour in mind, but fans of RGB lighting will have to spend more on the SL series’ Addressable RGB counterparts. The specifications of these fans are the same as the non-PWM AL series Prisma fans, aside from the fact that they lack RGB lighting capabilities and instead offer a single colour option.
(Fractal Prisma AL-120 fan)
Fractal Design’s new Prism SL and AL series fans are available worldwide starting today and worldwide pricing for these products are available to view in the table below.
You can join the discussion on Fractal Design’s Prisma series of RGB and static colour fans on the OC3D Forums.
