HAVN have new H-series PC fans, and they’re THICK!
HAVN will soon be ready to launch standalone PC case fans, and they look great!
We’ve visited the Pro Gamers Group booth at Computex 2025, and that booth included products from a ton of brands. We saw HAVN, noblechairs, Ducky, Nitro Concepts, and many others. Today, we will be starting our written coverage with HAVN and their upcoming H-series of PC case fans. Below, you can watch our video on the Pro Gamers Group booth.
(OC3D Pro Gamers Group Booth Tour)
THICK fans in 120mm, 140mm, and 180mm flavours
HAVN plans to launch its new H-series fans in September. These fans will be available in 120mm, 140mm, and 180mm sizes and in black/white. Note that all of these fans are thicker than the industry-standard 25 mm fans. HAVN’s 120mm and 140mm fans are 30mm thick, and their 180mm fans are 40mm thick. To our knowledge, this will make them the thickest fans on the market at launch. That’s great news, as thicker fans can push more air at lower speeds.
Note that HAVN’s fan frames are designed with cable tucking in mind. Also note that they feature male and female connectors for easy daisy-chaining. This enables easier cable management, and allows several fans to be powered using a single fan header. HAVN calls this their “Loopin” cable system.
HAVN’s fan blades are made using 30% glass fibre-reinforced composite. This makes them strong and rigid, ensuring high performance and minimal flexing or vibration. HAVN’s fans use custom blade designs to minimise noise and maximise performance.
HAVN is new to the PC market, but their HS420 case arrived with a bang (see our review here). Now, HAVN are planning to shake up the fan market with new thick-frame fan designs. These fans will be available as standalone products and with HAVN’s upcoming PC case designs.
You can join the discussion on HAVN’s new H-series fans on the OC3D Forums.
