HAVN unveils its BF 360 case at Computex
HAVN’s new BF 360 PC case looks like another hit PC case
We’ve visited the Pro Gamers Group booth at Computex 2025, and that booth included products from a ton of brands. We saw HAVN, noblechairs, Ducky, Nitro Concepts, and many others. One of the most exciting products from the booth was BF 360 case from HAVN, which is due to launch this September.
(OC3D Pro Gamers Group Booth Tour)
Meet the HAVN BF 360
At launch, the BF 360 will be available in two forms. First, there’s the case’s fanless model. Second, there is the game’s “with fans” model, which will ship with two 180mm fans and one 140mm fans. These will be some of HAVN’s new H-series PC fans.
Note that HAVN’s BF 360 PC case will be available in black or white. For this article, we mostly photographed the white version, as it was much easier to photograph.
For the “with fans” version of the BF 360, the case’s two 180mm fans will act as front intakes, and the case’s 140mm fan will act as an exhaust. Note that an airflow channel at the base of the BF 360 directs airflow towards the user’s graphics card. HAVN told us that this part underwent several design iterations to ensure GPU thermals were as low as possible.
Up to two 180 mm fans can be mounted at the top of the HAVN BF 360. Alternatively, users of this case can mount a 360mm liquid cooling solution here.
Note that one of this case’s top-mounted 180mm fans is used as an intake. HAVN says that this is an optimal configuration when this case is used with an air-based CPU cooler.
Below, we can see a baffle that HAVN has added to prevent unwanted airflow patterns inside the BF 360. Clearly, HAVN is taking airflow design seriously with this new PC case.
Honestly, I can’t wait to test this new PC case from HAVN. It’s due to be released this September, and will be available in Europe through Overclockers UK and Caseking.
You can join the discussion on HAVN’s BF 360 PC case on the OC3D Forums.
