HYTE launches new fans and accessories at Computex 2026
HYTE doubles down on fans and accessories at Computex 2026
Alongside their new Y50 PC case, HYTE has unveiled a new series of fans and PC accessories at Computex 2026. Many of these components are designed to complement modern PC builds, giving PC users an easy way to give their systems an aesthetic overhaul.
With its new THICC FR12 series fans, HYTE are offering PC builders thick 32mm fan models that offer users 360-degree RGB illumination. With their triple-fan Trio models, 68 total LEDs are available for illumination. HYTE’s FR12 fans are available in single-fan “Solo” and triple-fan single-frame “Trio” versions. These models are available in black and white, and with standard or reverse-blade fans. They also support daisy-chaining and boast “universal” PWM and ARGB compatibility.
HYTE’s FR12 Solo and Trio fans are available for $19.99 and $44.99, respectively. HYTE has also refreshed its existing FA-12 fan lineup with new G2 series models that deliver increased airflow and static pressure through a refined fan blade profile.
ARGB/PWM Smart Hub
Next we have HYTE’s new $29.99 Smart Hub, which can control ARGB and PWM signals. The hub is magnetic, allowing it to be attached to most PC cases with ease. It can control four independent PWM headers using HYTE’s Nexus Software. This hub will be available in Q3 2026.
ARGB Noodle LN80
HYTE’s newly revised ARGB Nuudle LN80 accessory will be available for $29.99, giving users flexible ambient lighting with 215-degree coverage. These can contour around HYTE’s Y40, Y60, and Y70 cases to deliver a clean, integrated lighting look. This can connect to standard ARGB headers, which means that no proprietary software or hardware is needed for full lighting customisation. Note that they HYTE Noodle LN80 is due to be released in Q3 2026.
Aesthetic Cable Extension kits
Finally, we have HYTE’s Aesthetic Cable Extension kits. These will be available for $69.99 in snow white, pitch black, strawberry milk, and taro milk. The kit includes a 12V-2×6 power cable and extensions for PCIe, CPU, and motherboard power connectors. These cables allow PSU cables to match HYTE’s PC case colour schemes, something that is impossible without custom PSU cables. Note that these cable extensions are due to release in Q3 2026.
You can join the discussion on HYTE’s newest products on the OC3D Forums.
