Monochrome glory! be quiet’s Pure Wings 3 fans are now available in white
Be Quiet have just launched new white versions of their Pure Wings 3 fans
be quiet have officially expanded their Pure Wings 3 series of fans with new white models. Until now, these fans were only available in black, but soon PC builders have a new monochromatic option for their new PC builds.
These new white Pure Wings series fans will be available in 120mm and 140mm sizes and in both low RPM and high-RPM forms. These four models are their 120mm PWM, 120mm PWM high-speed, 140mm PWM, and 140mm PWM high-speed. Like their black counterparts, these fans all feature newly designed fan blades and re-arranged angle result in strong air pressure characteristics. This makes these fans well suited for PC cases, heatsinks, and liquid cooling radiators.
be quiet’s Pure Wings 3 fans all feature a fan frame that is designed to minimise air leakage. This feature is great for use cases where high levels of static pressure are essential. Each fan is also designed to last for over 80,000 hours of use and to run quietly with their low starting RPMs.
Be quiet’s new Pure Wings series white fans will be available at retailers on February 13th. Below you can see the suggested retail prices of these new fans and some of their specifications. In the UK, all fan models will cost £10.99. This is very affordable when compared to the prices of many other premium fans. More information about these fans are now available on be quiet’s website.
You can join the discussion on be quiet’s Pure Wings 3 White fans on the OC3D Forums.
