MSI stuns with its new MPG VIXTA 300R AIRFLOW PZ PC case
MSI unveils its MPG VIXTA 300R AIRFLOW PZ PC case at Computex
If recent years have shown us anything, it’s that MSI needs to be taken seriously as a PC case manufacturer. Long gone are the days when PC cases from motherboard and GPU manufacturers offered little more than brand synergy. In recent years, MSI has produced some great PC cases that don’t need their branding to stand out as good products. At Computex 2026, MSI has shown off its new MPG VIXTA 300R Airflow PC case, a new chassis that adds to MSI’s list of great-looking PC cases.
(OC3D visits MSI’s Computex 2026 Booth)
The MPG VIXTA 300R will be released in July and will arrive in two forms. First, there is the case’s “Airflow” version, which features a mesh front panel and is equipped with two 160mm fans. The non-Airflow variant replaces this front panel with tempered glass and moves its front fans to the case’s side. Both models will be available in black and white.
The base of the VIXTA 300R has a floating aesthetic, giving fans at the base of the case direct access to cool air. This area can be used to display items, store USB pens, or kept open. The VIXTA also supports back-connect motherbards and features a PWM/ARGB control board, which simplifies cable management.
If you are interested in this PC case, know that MSI plans to launch its airflow version for $139 in the US and non-airflow version for $129.
You can join the discussion on MSI’s VIXTA 300R Airflow PC case on the OC3D Forums.
