Medusa Point incoming? AMD “Ryzen Air” 500 series CPUs Leak
AMD Ryzen Air 9 575 and Ryzen Air 7 555 CPUs leak
AMD may be moving to new Ryzen branding with its next-generation of Ryzen mobile CPUs. Hardware leaker HXL has shared the names of two new Medusa Point Low-Power (LP) CPUs: the Ryzen Air 9 575 and Ryzen Air 7 555. These new CPUs will utilise AMD’s Zen 6 CPU architecture and are likely to be unveiled at CES 2027.
According to HXL, AMD will retain its “Ryzen AI” brand for higher-power Medusa Point processors, while its low-power variants will have AMD’s new “AIR” branding. This is likely because they are better suited to lower-power, lightweight devices. This should help customers differentiate between AMD’s CPU tiers, with AMD offering Ryzen AIR, Ryzen AI, and Ryzen AI Max CPUs for laptops. These tiers move from low-power to mainstream and then ultra-high-end mobile CPUs, respectively.
As much as many people hate AMD’s “Ryzen AI” branding, introducing “Ryzen AIR” doesn’t seem like a step away from AI. That said, it does shift the focus away from AI for AMD’s more mainstream CPUs. This could be a good move for AMD, as buyers of more mainstream PCs are likely uninterested in AI-focused branding.
We expect to see some next-generation AMD products at CES 2026. These will likely arrive in the form of new Zen 6-powered mobile processors. However, AMD could also unveil new Ryzen desktop CPUs. After all, AMD’s AM5 CPU range is overdue for an upgrade.
Join the discussion on AMD’s “Ryzen Air” CPU leaks on the OC3D Forums.
