MSI Wows with its MEG CoreLiquid E15 360 CPU Liquid Cooler
MSI may have built the best-looking CPU cooler at CES 2026
At CES 2026, MSI has been showcasing its new MEG CoreLiquid E15 360 CPU liquid-cooling solution. This new CPU cooler is designed to deliver better cooling performance than MSI’s other offerings, while also offering a stronger aesthetic with its custom 2K screen and other add-ons.
Unlike other CPU coolers with 90-degree curved screens, MSI has opted for a 110-degree curvature, delivering increased visibility on both sides of the screen. This screen can deliver naked-eye 3D effects with the right content, or playback videos and GIFs while reporting detailed system information.
(OC3D’s tour of MSI’s CES 2026 Booth)
What makes the MEG CoreLiquid E15 360 special is its detailing. MSI hasn’t given its screen a plastic shroud; it sits within a gold frame. Similarly, their single-frame TriFlow fan features a golden aluminium outer frame, giving the cooler a premium aesthetic.
MSI has upgraded its MEG cooling solution with a 31mm-thick radiator to increase cooling surface area and performance. MSI has also streamlined their installation process by consolidating fan control, ARGB control, and USB signals into a single JAF_2 interface. This cooler is designed to look good, be easy to use, and deliver solid cooling performance.
MSI has not unveiled the release date of its MEG CoreLiquid E15 360 CPU cooler. However, we expect it to launch alongside MSI’s MEG Maestro 900R PC case.
You can join the discussion on MSI’s MEG CoreLiquid E15 360 CPU cooler on the OC3D Forums.
