Thermal Grizzly launch Intel Mycro Direct-Die PRO CPU Water Block
Cooler operation and added RGB lighting – Thermal Grizzly’s new Intel Mycro Direct-Die CPU water block promises to impress
Thermal Grizzly are taking Direct-Die CPU cooling to the next level with their new Intel Mycro Direct-Die Pro RGB V1 CPU water block. With this new design, thermal Grizzly promises up to a 6 degree drop in CPU thermals. That’s compared to their standard Direct Die CPU water block. This block already delivered significantly lower thermals than standard (non-Direct-Die) CPU water blocks.
With their new PRO Mycro variant, the block’s copper base has been overhauled. The block now feature a 43% increase in microfin count, and delivers lower coolant flow resistance. Additionally, the block features a new jet plate, and added acrylic glass elements that enable satisfying RGB lighting effects.
Thermal Grizzly is a relatively new company within the PC space, but this product launch has made it clear that they plan to continue innovating. Their new Intel Mycro PRO water block can push Intel 12th, 13th, and 14th generation CPU thermals to new lows. Yes, you will need to delid your CPU to utilise this cooling solution, but that’s what it takes to achieve the lowest possible CPU thermals.
Thermal Grizzly’s new Intel Mycro Direct-Die PRO RGB V1 cooler is available to order now from Thermal Grizzly. In US price of the block is $141.59, and the EU price for the block is $129.90.
You can join the discussion on Thermal Grizzly’s new Intel Mycro Direct-Die Pro CPU water block on the OC3D Forums.
