Want a Mac Pro case for your normal PC hardware? The Dune Pro may be the case for you
So what if you want the look of a Mac Pro and the versatility of a home-built PC? The answer is simple, get a Dune Pro, a Mac-like case that’s designed for consumer hardware.
At the time of writing the Dune Pro is not available for purchase, with pre-orders being due to start on October 21st via Kickstarter. The case is made primarily out of Aluminium and supports motherboards that are up to EATX in size, full-sized graphics cards and up to 360mm water cooling radiators. The case also supports a range of configurations that vary from HDD heavy builds to configurations with multiple graphics cards and other PCIe devices.
The Dune Pro is designed to look like a Mac Pro, that’s the Dune’s gimmick. At launch, two versions of the dune will be available, one of which features a simplified, drilled hole, front while the other offers a premium “Dice Y” cover which offers a more Mac Pro-like aesthetic and a patent-pending sound dampening technology. The case also features dua USB-C I/O ports that support USB 3.0 and USB 3.1 (10Gbps) support.
Airflow in this case uses a front-to-back configuration, where air comes from up to three 120mm fans at the front of the chassis and exits out the rear. The Dune Pro includes no fan mounts at the top of the enclosure.
At this time the pricing and availability of the Dune Pro are unknown. This information will be revealed when the Dune Pro’s Kickstarter begins on October 21st. More information about the Dune Pro is available here.
You can join the discussion on the Mac Pro-like Dune Pro PC case on the OC3D Forums.
