Corsair reveals their XENEON 27QHD240 OLED gaming monitor
Corsair’s new XENEON 27QHD240 OLED is an HDR gaming monster
Today, Corsair has revealed their new XENEON 27QHD240 OLED gaming monitor, a 240Hz OLED monitor that has a resolution of 2560×1440 (1440p) and a screen size of 27 inches.
Corsair’s new XENEON 27QHD240 OLED gaming monitor utilises a lot of cutting-edge technologies, offering gamers a 3rd generation OLED panel with META Technology featuring Micro Lens Array (MLA). This high-end OLED panel from LG offers users enhanced brightness levels for every pixel, delivering brighter highlights than other OLED displays while maintaining their super deep blacks.
With their XENEON 27QHD240 OLED, Corsair boasts strong burn-in protections and a Zero Burn-In warranty. On top of this, Corsair’s latest gaming screen promises users ultra-fast 0.03ms response times and 0.01ms pixel on/off times. These characteristics enable extremely low levels of motion blur, making this screen ideal for gamers, especially when combined with this monitor’s NVIDIA G-SYNC and AMD FreeSync Premium support.Â
Sadly, Corsair has not revealed the pricing of this new high-end OLED gaming monitor, though we can expect it to be expensive. The screen is due to launch in May 2023, so expect to hear more about this monitor before then.Â
Press Release –Â Corsair Announces XENEON 27QHD240 OLED Gaming Monitor
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today announced an exciting new addition to its lineup of high-performance gaming monitors, the XENEON 27QHD240 OLED. Combining the latest in LG OLED display technology with trademark CORSAIR style and performance, the XENEON 27 OLED offers superb black levels, self-lit OLED pixels, and blistering 240 Hz refresh rate, all in a 2560×1440 27-inch package ready to display everything your PC has to offer at its best.
Continuing the close partnership between CORSAIR and LG Display, the XENEON 27 OLED boasts a cutting edge 3rd generation OLED panel with META Technology featuring Micro Lens Array (MLA). This innovative new technology places a focal lens to enhance brightness in front of every pixel, boosting brightness far beyond previous generation OLED panels and delivering breathtaking color vibrancy. HDR10, 1,500,000:1 contrast ratio, a peak brightness of up to 1,000 nits and 98.5% DCI-P3 color gamut ensure that the brightest highlights, darkest details, and most nuanced colors are presented beautifully, whatever you’re playing, watching or creating.
The XENEON 27 OLED boasts rapid response times that leave previous generation gaming monitors behind. Up to 240 Hz refresh rate, 0.03 ms response time and 0.01 ms Pixel on/off time all-but eliminate motion blur, for class-leading gaming performance compatible with both NVIDIA G-SYNC and AMD FreeSync Premium.
The Xeneon 27 OLED also offers a wide range of customization options. With 60° of swivel, 22° of tilt, 100 mm (3.94-inch) of height adjustment, the ability to rotate 90° on its stand in either direction, or to be mounted on a monitor arm via its standard VESA mount, it’s easy to integrate the XENEON 27 OLED into an existing setup, or make it the showpiece of a new one.
Whether your setup is PC first, or console inclusive, the XENEON 27 OLED has all the connections you need. A pair of HDMI 2.1 ports, DisplayPort 1.4 and a USB Type-C DP Alt-Mode input allows it to be connected to 4 different devices at once (and two displayed simultaneously with picture in picture or picture by picture), while a USB 3.1 Type-C port and four USB 3.1 ports make it easy to connect the XENEON 27 OLED to full-equipped computers.
The front accessible controls also include an innovative proximity sensor to guide you to the correct button for Power ON/OFF, Input Select as well as the On Screen Display (OSD) joystick controller.
As with its stable-mate, the XENEON FLEX 45 OLED, the XENEON 27 OLED features an array of burn-in protection techniques to maintain a clean image, even following extended overlay, UI or operating system use, backed by a comprehensive three-year Zero Dead Pixel and Zero Burn In warranty.
Bringing the transformative leap forward in performance and image quality of OLED to a 27-inch display, XENEON 27 OLED shows everything your PC can do at its best.
Availability:
The new CORSAIR XENEON 27 OLED is on display throughout PAX East 2023 at the CORSAIR booth, Booth #18031.
Customers will be able to order the XENEON 27 OLED from the CORSAIR webstore and select channel partners in May 2023.
For more information, visit the product page.
You can join the discussion on Corsair’s XENEON 27QHD240 OLED gaming monitor on the OC3D Forums.
