Intel’s Comet Lake-S series CPUs will run hot – Sources Claim
AMD’s Ryzen 3000 series of Zen 2 powered desktop processors doubled AM4’s maximum core counts from eight to sixteen, a feat which was only possible thanks to the efficiency gains offered by AMD’s new Zen 2 architecture and TSMC’s 7nm fabrication technology. Even then, AMD’s rise in core count came with an increase in maximum power consumption, but most overclocking-ready AM4 motherboards could handle the additional strain. These factors don’t apply to Intel’s Comet Lake-S series.
With Comet Lake, Intel’s using the same 14nm process as its older Coffee Lake-S and Coffee Lake-R (Refresh) processors. Yes, Intel will call this a refined 14nm series node, but at this point, there are no more gains to be had on 14nm. Additionally, Intel will be using the same core architecture as before, which has been the case since the release of Skylake in 2015. These factors mean that Intel is increasing its core counts with no accompanying architectural changes or process tech advantages. When there are no efficiency gains to make, Intel’s increased core counts have to come with an increase in power consumption.
Increased power consumption means heightened heat production, something which will make Comet Lake-S series processors run hotter than their last-generation counterparts. This will force higher strain on CPU coolers and larger loads on compatible motherboards. This means that motherboard makers will need to invest in more capable VRM setups, larger VRM heatsinks and that end-users will need to invest in larger, more capable cooling solutions. That said, these insane cooling requirements only apply to Intel’s highest-end Comet Lake-S processors.
Intel is in a tough place. They have to compete with AMD, which means that they need to release desktop CPUs with more cores and higher levels of single-threaded performance. With a lack of architectural changes and node transitions in the desktop market, this will come at the cost of larger pieces of silicon and increased levels of power consumption. These factors will make AMD CPUs seem cooler running and more efficient.
Leaks of Intel’s i9-10900F processor suggests that the CPU will feature a PL1 rating of 170W and a PL2 rating o 224W, highlighting the power that the processor can draw while accessing its highest performance levels. These values could be even higher with Intel’s flagship i9-10900K processor, a factor which will likely make liquid cooling a necessity.
We will reserve our opinions on Intel’s Comet Lake-S series processors until we have had time to review them. That said, Comet Lake is likely to be the same story as Intel’s previous launched. Will this be Coffee Lake-R with two more cores bolted on?
You can join the discussion on Intel’s Comet Lake-S series processors on the OC3D Forums.
