Intel’s Skylake-X and Kaby Lake-X CPUs will not be soldered
The problems that arise from using non-soldered CPUs occur because the TIM used by Intel will not have the same thermal conductivity as a directly soldered CPU, which will cause Intel’s CPUs to run hotter, especially when overclocked.
This is the first time that Intel has not soldered their high-end desktop CPUs, a move which will no doubt force overclockers to delid their “premium” CPU in order to achieve the same thermal efficiency as Intel’s last generation hardware. This move will no doubt be seen negatively by PC enthusiasts, especially after they learn how expensive a proper delidding tool can be.
You can join the discussion on Intel’s Skylake-X and Kaby Lake-X CPUs being unsoldered on the OC3D Forums.
