ACER reveals a huge lineup of Radeon RDNA 3 graphics cards at CES
ACER plans to fully enter the GPU market with their new lineup of Radeon RDNA 3 graphics cards
At CES 2024, Acer has revealed four Radeon RDNA 3 RX 7000 series graphics cards. This new GPU lineup from Acer will be available both in Europe and the US, and will include AMD’s newly revealed Radeon RX 7600 XT 16GB.
Acer will be launching Radeon RX 7800 XT, Radeon RX 7700 XT, and Radeon RX 7600 XT GPU models. At this time it is unknown if Acer plans to create any higher-end Radeon products, or create an 8GB Radeon RX 7600 non-XT graphics card.
(Image from Acer)
Leading this new lineup of Acer RDNA 3 graphics cards is the Predator RX 7800 XT BiFrost. This graphics card features a triple-fan heatsink design and features 16GB of GDDR6 memory. This graphics card utilises Acer’s FrostBlade 3.0 fans
Predator BiFrost AMD Radeon RX 7800 XT OC graphics card
The Predator BiFrost AMD Radeon RX 7800 XT OC graphics card fuses the prowess of the AMD RDNA 3 chiplet design and Acer’s latest technology advancements. Gamers can expect major leaps in performance and efficiency with PCIe 4.0 and dual PCIe 8-PIN connectors. With a massive 16 GB GDDR6 memory and 624 Gbps bandwidth, the Predator BiFrost AMD Radeon RX 7800 XT OC graphics card delivers lightning-fast processing and visual fidelity in every frame, plus clock speeds that reach up to a 2,254 MHz game clock and up to 2,565 MHz boost clock for smooth responsiveness.
Crafted with precision, the Predator BiFrost AMD Radeon RX 7800 XT OC graphics card houses a robust cooling system with triple Predator FrostBlade 3.0 fans, a distinct ringed design, and wave-patterned blade texture to enhance airflow, paired with an efficient vapor chamber to optimize heat dispersion. DIY gamers will appreciate the sleek design measuring 281.9 x 117.9 x 61.4 mm and occupying 3 slots, making it a great fit for a wide range of gaming rigs. For added versatility, connectivity options include an HDMI 2.1 port and three DisplayPort 2.1 ports for easy device integration. Finally, the Predator BiFrost Utility App lets gamers oversee the device’s performance and calibrate fan velocities and graphics parameters to their desired settings.
Next up we have Acer’s Nitro Radeon RX 7800 XT and RX 7700 XT graphics cards. Both of these GPUs feature a dual-fan design and a neat all-black aesthetic. Both GPUs are 2.5-slots thick and are 279 mm long, making them compatible with most PC cases.
Acer Nitro AMD Radeon RX 7800 XT OC and Acer Nitro AMD Radeon RX 7700 XT OC graphics cards
The Acer Nitro AMD Radeon RX 7800 XT OC and Nitro AMD Radeon RX 7700 XT OC graphics cards are primed to present the latest games in their full visual splendor. They blend redesigned AMD RDNA 3 compute units with unified raytracing and AI accelerators to take gamers on a mesmerizing journey in 1440p and 4K gaming. The Nitro Radeon RX 7700 graphics card’s game clock speed scales up to an impressive 2,276 MHz and the boost clock reaches up to an astounding 2,599 MHz. The Nitro Radeon RX 7800 graphic card’s game clock goes up to 2254 MHz while its boost clock reaches up to 2565 MHz to support graphic-intensive games and tasks.
The new Acer Nitro graphic cards feature a new encode/decode media engine for high-definition encoding capabilities. Whether it is exploring gaming realms, streaming videos, or creating designs, users can experience ultra-enhanced multimedia, elevated color spectrums, and dynamic enhancements with full AV1 encode/decode support.
Users don’t need to worry about overheating as the Acer Nitro AMD Radeon RX 7800 XT OC and Nitro AMD Radeon RX 7700 XT OC graphics cards feature dual Nitro FrostBlade ringed fans to improve airflow and dispel heat from the heatsink and away from the GPUs. Their dual-ball bearing systems serve to decrease noise, withstand high temperatures, and help minimize the fans’ wear and tear. The advanced cooling system lies beneath its thoughtfully designed exterior, with dimensions of 279 x 129.62 x 50.42 mm and 2.5-slot designs so gamers can maximize space without compromising performance. For added flexibility, the graphics cards come with one HDMI 2.1 port and three DisplayPort 2.1 ports.
Finally, we have Acer’s Nitro Radeon RX 7600 XT, another dual-fan RDNA 3 graphics card. This GPU features 16GB of GDDR6 memory and boasts three DisplayPort 2.1 outputs and a single HDMI 2.1 connector. This graphics card will be powered by two 8-pin PCIe power connectors, giving this GPU ample power for overclocking.
Acer Nitro AMD Radeon RX 7600 XT OC graphics card
The Acer Nitro AMD Radeon RX 7600 XT OC graphics card incorporates cutting-edge features for reliable performance. Gamers get a competitive edge and impressive responsiveness with 16 GB of GDDR6 memory and a staggering 288 Gbps bandwidth, along with game clock speeds of up to 2,539 MHz and a 2,810 MHz boost clock.
To maintain its superb performance, the advanced cooling technology features dual Nitro FrostBlade ringed fans engineered to maximize both high airflow and pressure and effectively dissipate heat from the GPU. The dual-ball bearing system can withstand high temperatures and minimize friction on the fan bearings, while three dissipation holes ensure effective cooling of the device’s vital components. To ensure optimal performance, the Acer Nitro AMD Radeon RX 7600 XT OC graphics card’s cooler is reinforced with a copper base to efficiently absorb heat and dispel it through oxygen-free heat pipes. The capacitors on its PCB board are designed with durability as the priority, boasting a lifespan of 2.5 times longer than that of a regular capacitor. The device is further reinforced with an aluminum backplate and metal anti-bending strip that also supports the device’s temperature control.
Compact yet powerful, the Acer Nitro AMD Radeon RX 7600 XT OC graphics card’s dimensions measure 268 x 111.2 x 40.1 mm, and a 2.5-slot form factor, a suitable choice for space-conscious DIY gamers. It is also equipped with an array of vital connectivity ports, including one HDMI 2.1 and three DisplayPort 2.1 ports. With a digital maximum resolution of 7680 x 4320 and the ability to support simultaneous display of 4 monitors, users can indulge in stunning visuals across multiple screens for an enveloping gaming experience.
Pricing and Availability
Acer has confirmed that they plan to release all of their new RDNA 3 graphics cards this February in the US, and in Q1 2023 in EMEA area. Below are the company’s prices for their Radeon RDNA 3 based graphics cards.
- Acer Predator BiFrost AMD Radeon RX 7800 XT OC graphics card – $549.99 – 599 Euro
- Acer Nitro AMD Radeon RX 7800 XT OC – $509.99 – 579 Euro
- Acer Nitro AMD Radeon RX 7700 XT OC – $459.99 – 519 Euro
- Acer Nitro AMD Radeon RX 7600 XT OC graphics card – Unknown Pricing
You can join the discussion on ACER’s upcoming Radeon RDNA 3 graphics cards on the OC3D Forums.
