AMD Radeon RX 9060 XT Pricing and Specifications Leak
AMD aims for another Price/performance win with its Radeon RX 9060 XT
Specifications and pricing for AMD’s Radeon RX 9060 XT graphics card have leaked, revealing what could be another price/performance win for AMD and its RDNA 4 graphics architecture.
Based on a new leak from Moore’s Law is Dead, AMD’s Radeon RX 9060 XT will feature 32 compute units. The graphics card is also said to be launching with 8GB and 16GB variants. Performance-wise, this new GPU should sit between Nvidia’s RTX 4060 Ti and AMD’s Radeon RX 7700 XT. This means that this new GPU will be much faster than AMD’s last-generation RX 7600 and RX 7600 XT GPUs.
AMD is reportedly targeting a price range of $269-$299 for the 8GB Radeon RX 9060 XT and $329-$379 for the 16GB model. This places AMD’s new GPUs in direct competition with Nvidia’s RTX 5060 and RTX 5060 Ti, based on expected pricing and performance.
There are also reports that AMD are considering a Radeon RX 9050 XT graphics card, which should target sub-$250 pricing.
(Image from Moore’s Law is Dead)
Another RDNA 4 success from AMD?
AMD’s RDNA 4 graphics architecture delivers much more gaming performance per compute unit than AMD’s RDNA 3 graphics architecture. With this in mind, we should expect major performance gains over AMD’s RX 7600 series with AMD’s new RX 9060 XT graphics cards. This is excellent news for gamers. After all, better gaming performance from a mainstream GPU is a good thing. That said, it remains to be seen how these GPUs will perform in real-world gaming scenarios.
| Radeon RX 9070 XT | Radeon RX 9070 | Radeon RX 9060 XT (leaked) | AMD Radeon RX 7600 XT | |
| Architecture | RDNA 4 | RDNA 4 | RDNA 4 | RDNA 3 |
| Node | 4nm | 4nm | 4nm | 6nm |
| Compute Units | 64 | 56 | 32 | 32 |
| Stream Processors | 4096 | 3584 | 2048 | 2048 |
| “Game” Clock Speed | 2400 MHz | 2070 MHz | ??? | 2470 MHz |
| Boost Clock Speed | 2970 MHz | 2520 MHz | ??? | 2755 MHz |
| GDDR6 Memory | 16GB | 16GB | 8GB or 16GB | 16GB |
| GDDR6 Speed | 20 Gbps | 20 Gbps | 19.5 or 20 Gbps | 18 Gbps |
| Memory Bis Size | 256-bit | 256-bit | 128-bit | 128-bit |
| PCIe | 5.0 | 5.0 | ??? | 4.0 |
You can join the discussion on AMD’s Radeon RX 9060 XT specifications leak on the OC3D Forums.
