AMD’s Radeon RX 6600 XT and RX 6600 specifications Leak Online
Both AMD’s RX 6600 and RX 6600 XT are due to feature 8GB of GDDR6 memory over a 128-bit memory bus, featuring 28 and 32 compute units, respectively. At this time, the clock speeds of these two graphics cards are unknown, though they are not likely to be as aggressively clocked as AMD’s RX 6700 XT models.
AMD’s RX 6600 and RX 6600 XT will target 1080p and 1440p gaming, offering consumers support for DirectX 12 Ultimate features like ray tracing acceleration, Variable Rate Shading and Sampler Feedback; all of which are vital parts of the next-generation gaming feature set. Both graphics cards also feature more performance than Microsoft’s Xbox Series S, which only features 20 RDNA 2 Compute Units.
At this time, we can only guess at the relative pricing of AMD’s RX 6600 XT and RX 6600, though they are likely to be competitors to Nvidia’s RTX 3050 Ti and RTX 3060. Given the state of today’s GPU market, we will not even attempt to guess how much these graphics cards will cost.
In an EEC listing, ASRock has already signalled that they will be releasing RX 6600/6600 XT GPU models under their Challenger D, Challenger ITX, Challenger Pro, and Phantom Gaming brands. This suggests that AMD’s board partners are almost ready for launch.
| Radeon RX 6600 (Leaked) |
Radeon RX 6600 XT (Leaked) |
Radeon RX 6700 XT (Reference) |
Radeon RX 6800 (Reference) |
Radeon RX 6800 XT (Reference) |
Radeon |
| Compute Units | 28 | 32 | 40 | 60 | 72 | 80 |
| Shaders | 1792 | 2048 | 2560 | 3840 | 4608 | 5120 |
| Game Frequency | ? | ? | 2424 MHz | 1815 MHz | 2015 MHz | 2015 MHz |
| Boost Frequency | ? | ? | 2581 MHz | 2105 MHz | 2250 MHz | 2250 MHz |
| VRAM Size | 8GB | 8GB | 12GB | 16GB | 16GB | 16GB |
| VRAM Speed | 16Gbps | 16Gbps | 16Gbps | 16Gbps | 16 Gbps | 16 Gbps |
| Infinity Cache | 64MB | 64MB | 96MB | 128MB | 128MB | 128MB |
| Power Inputs |
? | ? | 8-pin & 6-pin |
2×8-pin | 2×8-pin | 2×8-pin |
You can join the discussion on AMD’s Radeon RX 6600 XT and RX 6600 specifications on the OC3D Forums.
