EVGA announce their GTX 1080Ti FTW3
EVGA has now shown their new GTX 1080Ti GPU with an all new FTW3 triple fan cooler design, which should offer a significant upgrade in cooling performance over their current dual-fan cooler designs.
Right now Nvidia estimates that the GTX 1080T will offer a 35% performance boost over their GTX 1080 in most gaming titles, though this new FTW3 model from EVGA will almost certainly come with a factory overclock and offer even more performance.
This graphics card with 11GB of GDDR5X memory, operating at 11000MHz, giving these GPUs a total of 484GBPS of memory bandwidth, which is more than Nvidia’s Titan X Pascal. Below is the specification of Nvidia’s reference GTX 1080 Ti.
| GTX Titan X | GTX 1080 Ti | GTX 1080 | GTX 1070 | GTX 1060 | |
| GPU Architecture | Pascal | Pascal | Pascal | Pascal | Pascal |
| Process node | 16nm | 16nm | 16nm | 16nm | 16nm |
| SM Units | 56 | 56 | 40 | 30 | 20 |
| Cores per SM | 64 | 64 | 64 | 64 | 64 |
| CUDA Core Count | 3584 | 3584 | 2560 | 1920 | 1280 |
| ROPs | 96 | 88 | 64 | 64 | 32 |
| VRAM Type | GDDR5X | GDDR5X | GDDR5X | GDDR5 | GDDR5 |
| Memory Clock | 10008MHz | 11008MHz | 10008MHz | 8008MHz | 8008MHz |
| VRAM Cappacity | 12GB | 11GB | 8GB | 8GB | 6GB |
| Memory Bus Size | 384-bit | 352-bit | 256-bit | 256-bit | 192-bit |
| Memory Bandwidth | 480 GB/s | 484 GB/s | 320 GB/s | 256 GB/s | 192 GB/s |
| Base clock speed | 1417MHz | – | 1607MHz | 1506Mhz | 1506MHz |
| Boost clock speed | 1531MHz | 1582MHz | 1733MHz | 1683MHz | 1708MHz |
| TDP | 250W | 250W | 180W | 150W | 120W |
| Power Connection | 1x 8-pin 1x 6-pin |
1x 8-pin 1x 6-pin |
1x 8-pin | 1×8-pin | 6-pin |
| PCI Express | PCIe 3.0 | PCIe 3.0 | PCIe 3.0 | PCIe 3.0 | PCIe 3.0 |
Right now it is unknown what clock speeds this new GTX 1080Ti will offer, or if this model will have a considerable price increase over Nvidia’s reference/founders edition models.
You can join the discussion on EVGA’s GTX 1080Ti FTW3 on the OC3D Forums.
