LG launch their 42.5-inch 4K 43UD79-B FreeSync Monitor
LG has now launched their 42.5-inch 4K 43UD79-B FreeSync Monitor, which can display inputs from multiple devices at once.
This display comes with a refresh rate of 60Hz and an undefined FreeSync range (thought to be 56-61Hz based on display’s spec sheet), which combined with this display’s 8ms Grey-To-Grey response time will make this display ill-suited to gamers. This display is intended to be used for productivity, especially by those that will take advantage of Picture-in-Picture mode to control multiple systems at once.
The 43UD79-B will come with four HDMI inputs, two of which are HDMI 2.0 and two which are HDMI 1.4. There is also a single DisplayPort 1.2a input on this display, as well as two USB 3.0 ports.
The LG 43UD79-B will use a IPS panel which is said to support 10-bit colour, though at this time it is unknown if this is a 10-bit panel or a display at is 8-bit and supports 10-bit colour through display dithering to provide 10-bit colour depth.
With Picture in picture mode, this display can be used to display outputs from multiple systems, allowing this large display to be split into up to 4 separate 1080p outputs. This will allow those working with this monitor to easily split this display for optimal workflow.
Right now this display is available to Pre-order for $697 at US retailers, with expected availability from May 9th. At this time it is unknown when this display will reach the UK/European markets, or what price this display will be in Pounds or Euros.
You can join the discussion on LG’s 42.5-inch 4K 43UD79-B FreeSync monitor on the OC3D Forums.
