MSI announce their GTX 1080 Ti SEA HAWK EK X GPU
MSI has announced their new GTX 1080 Ti SEA HAWK EK X GPU, which comes with a pre-installed EK water block and a significant factory overclock.
This GPU will come with an MSI themed EK water block design, with both MSI and EK logos on the block itself and a custom MSI backplate. On this GPU’s rear IO this GPU will feature dual HDMI 2.0 ports, dual DisplayPort 1.4 ports and a single DVI-D connection.
Below is a table that compares the base and boost clock speeds of MSI’s GTX 1080 Ti SEA HAWK EK X with that of Nvidia’s reference/Founders Edition model.
  GTX 1080 Ti Founders Edition EVGA GTX 1080 Ti SC2 Hybrid
GPU Architecture Pascal Pascal
Process node 16nm 16nm
SM Units 56 56
Cores per SM 64 64
CUDA Core Count 3584 3584
ROPs 88 88
VRAM Type GDDR5X GDDR5X
Memory Clock 11008MHz 11024MHz
VRAM Cappacity 11GB 11GB
Memory Bus Size 352-bit 352-bit
Memory Bandwidth 484 GB/s 484 GB/s
Base clock speed 1480MHz 1569MHz
Boost clock speed 1582MHz 1683MHz
TDP 250W 250W
Power Connection
1x 8-pin 1x 6-pin
1x 8-pin 1x 8-pin
PCI Express  PCIe 3.0 PCIe 3.0
Right now MSI’s new GTX 1080 Ti Sea Hawk EK X is available to Pre-order at overclockers UK for £899.99.
You can join the discussion on MSI’s GTX 1080 Ti Sea Hawk EK X on the OC3D Forums.
