Samsung has built the world’s first 1100Hz gaming monitor
Samsung’s new 1100Hz monitor will be available next month in the US
Samsung has just launched its new 27-inch Odyssey G6 (G60H) monitor, the first monitor to boast a 1100Hz refresh rate. Yes, this screen can run at 1100 Hz, but that resolution comes at a cost. At $899.99, this monitor is expensive, and at its maximum resolution of 2560 x 1440 (QHD/1440p), it runs at up to 600 Hz.
The Samsung Odyssey G6 (G60H) is a dual-mode monitor. This lets users choose between 1440p at 600 Hz and HD (720p) at 1100 Hz. The screen uses a Fast IPS panel with a 1ms grey-to-grey (GtG) response time and supports Samsung HDR10+ Gaming. The screen also supports AMD FreeSync Premium and is Nvidia G-Sync Compatible.
Samsung has confirmed that this monitor will be available in the US for $899.99 in December 2026. European availability remains unknown. The screen features one DisplayPort 2.1 port and two HDMI 2.1 connections. Samsung also claims that this screen uses an “optimised blur reduction algorithm” to reduce motion blur with “Odyssey Clear Motion”. Samsung also plans to bring this technology to “more gaming monitors” in the future.
There’s no doubt about it: the Samsung Odyssey G6 (G60H) is a fast monitor. 600Hz at 1440p and 1100Hz at 720p are incredible refresh rates. That said, running games at 720p in 2026 (almost 2027 by the time this launches) will be a hard ask for some gamers. Yes, many competitive games won’t benefit much from higher resolutions, but 1080p has been the standard for ultra-high refresh rate monitors for over a decade. Asking competitive gamers to switch to something lower could be a problem.
Join the discussion on Samsung’s new Odyssey G6 (G60H) gaming monitor on the OC3D Forums.
