Top Tier Ryzen memory – G.Skill launches Trident Z5 Royal NeoX AMD EXPO ULL DDR5 memory kits
G.Skill unveils “luxury-class” EXPO ULL DDR5 memory for AMD Ryzen CPUs
G.Skill has released its first “luxury-class” EXPO ULL DDR5 memory modules for AMD Ryzen CPUs, pairing Trident Z5 Royal NeoX aesthetics with ultra-tight memory timings.
With AMD EXPO ULL support, these DDR5 memory modules feature fine-tuned memory subtimings that help PC builders get the most out of their systems. These ultra-tight ULL (Ultra Low Latency) timings require a compatible AMD Ryzen CPU and a compatible motherboard/BIOS to access.
These new Trident Z5 Royal DDR5 modules are available with DDR5-6000 speeds with timings as low as CL26-36-36-32. Optimal timings for gamers who demand the best memory performance.
These new Trident Z5 Royal NeoX DDR5 memory kits are available in 32GB (2x16GB) configurations. Pricing will vary depending on the memory timings you choose. With their optimised ULL subtimings, these modules will deliver stronger memory performance than standard AMD EXPO memory modules.
With their mirrored silver or gold finishes and crystalline light bars, G.Skill’s AMD EXPO ULL Trident Z5 Royal NeoX memory modules are truly “luxury-class” DRAM modules. If you expect these DDR5 modules to be affordable, you are delusional, especially in today’s memory market.
Join the discussion on G.Skill’s Trizent Z5 Royal NeoX EXPO ULL DDR5 memory kits on the OC3D Forums.
