E3D and Bambu Lab team up to create ObXidian nozzles for their X1 and P1 3D printers
UK-based hot-end manufacturer E3D creates spectacular upgrade for the Bambu Lab X1 and P1 3D printers
If you are into 3D printer upgrades, you will know that E3D create some of the best upgrades available. Now, E3D have teamed up with Bambu Lab to create an ObXidian hot-end upgrade for their X1 and P1 3D printers. This upgrade allows users to increase their flow rates by 60%, enabling faster printing on compatible Bambu Lab 3D printers.
What’s even better is the fact that E3D has designed their new nozzle to be a drop-in replacement for the stock nozzles on compatible Bambu Lab 3D printers. The nozzle also features a hardened nozzle, making the nozzle more durable and precise. This hardened nozzle also ensures strong results with abrasive 3D printing materials. Note that this upgrade is only for the Bambu Lab X1 and P1, it is not compatible with the Bambu Lab A1 Mini.
E3D have also invested in a non-stick coating called E3DLC, which helps to prevent filament residue from sticking to the nozzle. This helps to prevent nozzle clogs and helps to increase the reliability of your 3D printer. E3D doesn’t just want your 3D printer to be faster, then want it to be more reliable too.
Key Features of the E3D ObXidian Bambu Lab P1/X1 Upgrade:
1. Drop-in Replacement HotEnd: The E3D upgrade serves as a drop-in replacement HotEnd for Bambu X1 and P1 Series printers, ensuring a hassle-free integration process. Users can easily transition to the enhanced performance without any complex modifications.
2. 60% Additional Flowrate: Experience a remarkable 60% increase in flowrate compared to the standard Bambu HotEnd. This substantial boost in performance translates to faster print speeds and improved efficiency, making it an essential upgrade for users seeking enhanced
productivity.
3. ObXidian Hardened Tipped Nozzle: The upgrade features the state-of-the-art ObXidian hardened tipped nozzle, providing superior durability and precision. This innovative nozzle ensures consistent and reliable 3D printing results, even with challenging abrasive materials.
4. E3DLC Coating for Non-Stick Properties: The E3DLC coating on the upgraded HotEnd offers advanced non-stick properties, reducing the likelihood of filament residue and clogs. This feature enhances the overall reliability of the printing process, minimizing maintenance and downtime.
5. Officially Approved & Licensed Bambu Product: E3D’s upgrade is officially approved and licensed by Bambu, guaranteeing compatibility and adherence to the highest standards. Users can trust the authenticity of the product and its seamless integration with Bambu X1 and P1 Series printers.
6. Competitive Pricing: The E3D upgrade is priced to offer great value for money without compromise. At an attractive £60 (excl. tax), it provides an affordable and accessible solution for users looking to enhance the performance of their Bambu printers.
Pricing and availability
E3D’s new ObXidian Hot-End upgrade is now available for £60 on E3D’s official website.
You can join the discussion on the E3D ObXidian hot-end for Bambu Lab 3D printers on the OC3D Forums.
