Xbox details Project Helix “Innovation” at GDC 2026
Xbox details Project Helix at GDC 2026
At their “building for the future with Xbox” event at GDC 2026, Microsoft detailed some of the “innovation” inside their next-generation “Project Helix” console.
As mentioned before, Microsoft has confirmed that this new system will play both Xbox Console and PC games. Furthermore, Microsoft has confirmed that this new system will use a “custom AMD SOC” that has been “codesigned for the next generation of DirectX”.
Xbox has also confirmed that this hardware will feature “next-generation raytracing performance & capabilities” and will feature “GPU directed Work Graph Execution“. The system will also support AMD’s “FSR Next” technologies, which include next-generation ML upscaling, ML Multi-Frame Generation, and Next-generation Ray Regeneration for path-traced games.
Finally, Microsoft has unveiled “Neural Texture Compression” alongside “DirectStorage + Zstd” support. This means increased memory efficiency and stronger game compression.
(Images via IGN)
At GDC, Microsoft has unveiled several things. First, there will be a new generation of DirectX. Next, Microsoft is working alongside AMD on its next-generation FSR technologies. Furthermore, Xbox plans to support path-traced games with its new console.
Microsoft has also unveiled parts of AMD’s future GPU roadmap. For starters, AMD has not unveiled ML-powered Multi-Frame Generation technology. So far, AMD only has 2x ML-powered Frame Generation technology. It also suggests that AMD has newer versions of its FSR ML upscaling and ray regeneration technologies in the works.
Clearly, Project Helix is a console for the AI and ray tracing eras. This places this new system in a class above today’s Xbox Series consoles. Overall, these innovations will act as a strong baseline for a new console generation. Furthermore, Microsoft’s “next generation” DirectX plans should have a huge impact on PC gamers.
You can join the discussion on Microsoft’s Project Helix “innovation” on the OC3D Forums.
