BIG POWER – Enermax launches several 2000W+ PSUs at Computex
Big Watts, High Efficiency – Enermax reveals a wide range of ultra-powerful PSUs at Computex 2024
At Computex 2024, Enermax has revealed a large number of high wattage power supplies, the most powerful of which can deliver 2400 watts of power. That’s an insane amount of power, being strong enough to run multi-GPU AI systems and other ultra-powerful workstations.
Within Enermax’s MaxTytan Digital range we have a 1650W unit with 80+ Titanium Efficiency, and a 2000W unit with 80+ Gold Efficiency (230V only). These PSUs are both ATX 3.1 certified and feature a semi-fanless design. This design ensures that fans remain static until 60+% loads.
For those wo crave as many watts as possible, Enermax has their new 2400W Platimax power supply. This is an 80+ Platinum rated power supply that is both ATX 3.1 and PCIe 5.1 complaint. The PSU features two 12V-2×6 power outputs.
This power supply is 18cm deep, which is longer than most standard ATX power supplies. Like other modern Enermax PSUs, this 2400W unit has a semi-passive fan design. This unit’s large fan does not turn on until 60+% power loads.
You can join the discussion on Enermax’s Computex 2024 high wattage PSU reveals on the OC3D Forums.
