343i Reveals Halo Reach’s PC system requirements
As you can imagine, given Halo Reach’s origins as an Xbox 360 title, Halo: Reach’s PC system requirements are very modest by today’s standards, with 4K gameplay being a possibility on graphics cards like AMD’s Radeon RX 480.Â
Right now, 343 Industries has released Minimum, 1080p Minimum and 4K Minimum system requirements for Halo: Reach for both AMD/Radeon and Intel/Nvidia powered systems. In time, PC system requirements for systems with Integrated graphics will be rated for Halo: Reach’s PC version. These PC system requirements are for the Steam version of the game, with Microsoft noting that the “specs will be slightly different for the Windows Store version”.
At this time, we do not know why the Windows Store’s specifications will be different than what we see on Steam. At this time Halo Reach has no firm release date on PC.Â
On PC, Halo Reach will support separate Field of View options for Vehicles and First-Person viewpoints and offer players support for Resolution Scale options and multiple aspect ratios. This should allow PC gamers with 1080p monitor to downsample Halo Reach from higher resolutions if their hardware is up to the task. This is great news for PC gamers with high-end GPUs in their systems.Â
Below are Halo Reach’s PC system requirements.Â
Minimum Spec AMD/Radeon
CPU: AMD Phenom II X4 960T
GPU: Radeon HD 6850
RAM: 8GB
AVG FPS: 51-55
Minimum Spec Intel/Nvidia
CPU: Intel i3-550
GPU: Nvidia GTS 450
RAM: 8GB
AVG FPS: 52-54
Minimum 1080p AMD/Radeon
CPU: AMD FX-4100
GPU: Radeon R7 360
RAM: 8GB
AVG FPS: 61-62
Minimum 1080p Intel/Nvidia
CPU: Intel i7-870
GPU: Nvidia GTX 560 Ti
RAM: 8GB
AVG FPS: 59-61
Minimum 4K AMD/Radeon
CPU: FX-8350
GPU: Radeon RX 480
RAM: 8GB
AVG FPS: 60-62
Minimum 4K Intel/Nvidia
CPU: i5-3450
GPU: GTX 770
RAM: 8GB
AVG FPS: 60
You can join the discussion on Halo Reach’s PC version on the OC3D Forums.Â
