AMD brings FSR 4.1.2 to Unreal Engine 5 with an official plugin
AMD FSR 4.1.2 is now available for Unreal Engine 5.3 to 5.8
AMD has updated its FSR plugin for Unreal Engine 5, adding FSR 4.1.2 support to Unreal Engine 5.3-5.8. This update adds AMD ML-based FSR Upscaling technology to Radeon RX 6000 series GPUs and AMD Ryzen integrated graphics solutions.
With this new plugin, AMD’s ML-based FSR 4.1 upscaling is available to AMD Radeon RX 9000, RX 7000, and RX 6000 GPUs as well as many AMD RDNA-based Ryzen integrated graphics solutions.
This new plugin uses AMD’s FSR Redstone SDK 2.4, which also adds AMD’s new Frame Generation 4.0.2 technology with FSR Frame Generation Swapchain 4.0.0. This adds driver-assisted Frame Pacing to Radeon RX 9000 series GPUs, making frame delivery smoother. This feature requires Windows 11 and AMD Software 26.10.1 (or newer drivers).
AMD has also released a new Radeon Anti-Lag plugin for Unreal Engine 5, with performance and stability improvements. This feature reduces end-to-end system latency in GPU-bound scenarios.
(AMD’s newest Unreal Engine 5 FSR Plugins)
Unfortunately, this FSR plugin release doesn’t support AMD’s FSR 4 ML upscaling via the Vulkan API. This is despite FSR 4.1 ML upscaling now being available for Vulkan-based PC games. DOOM: The Dark Ages now supports AMD’s FSR 4 ML-powered upscaler. AMD says to “stay tuned for future plugin updates” if you want to use FSR 4.1 upscaling on Unreal Engine 5 with the Vulkan API.
Join the discussion on AMD’s new FSR plugin for Unreal Engine 5 on the OC3D Forums.
