Details of AMD’s Navi 14 and Navi 12 chips leak – Big Navi and Small Navi
Details of AMD's Navi 14 and Navi 12 chips leak - Big Navi and Small Navi
Rumour has it that AMD plans to release high-end and low-end Radeon Navi graphics cards before the end of 2019, challenging Nvidia’s high-end RTX offerings as well as the company’s low-end GTX-16XX series.
With this move, AMD will bring RDNA to an incredibly wide audience, fully replacing the company’s ageing Polaris lineup with stronger, more power-efficient product offerings.
Now, specifications for AMD’s rumoured Navi 12 and Navi 14 GPU designs have leaked, pointing towards Navi/RDNA products with as many as 4096 stream processors. Yes, AMD will have a proper challenger to Nvidia’s RTX 2080 Super, assuming that these rumours are correct.
On the low-end, we have Navi 14, which allegedly offers up to 1536 stream processors and acts as a replacement for AMD’s RX 570, RX 580 and RX 590 graphics cards. This will take the fight to Nvidia’s Geforce GTX 1660, which is perhaps why Nvidia seemingly has a GTX 1660 Super in the works.
On the high-end, we have AMD’s Navi 12 graphics chip, which basically acts as an RDNA version of AMD’s RX Vega 64 silicon on 7nm with GDDR6 memory. That’s right, AMD’s Navi architecture with a stream processor count of up to 4096. That’s 60% more stream processors than the Radeon RX 5700 XT. With this card, AMD has the chance to surpass Nvidia’s RTX 2080 Super.
Leaked Navi 12 (RX 5800/5800XT) AMD RX 5700 XT 50th Ann. Edition AMD RX 5700 XT AMD RX 5700 Leaked Navi 14 (5600/5600XT)
Core Design Navi 12 Navi 10 Navi 10 Navi 10 Navi 14
Process Tech/ Architecture 7nm Navi 7nm Navi 7nm Navi 7nm Navi 7nm Navi
Stream
Processors
3328-4096 2560 2560 2304 1536
Base
Clock
– 1680MHz 1605MHz 1465MHz –
Gaming
Clock
– 1830MHz 1755MHz 1625MHz –
Boost
Clock
– 1980MHz 1905MHz 1725MHz –
Memory
8GB GDDR6 8GB GDDR6 8GB GDDR6 8GB GDDR6 4/8GB GDDR6
Memory
Bus
256-bit 256-bit 256-bit 256-bit 128-bit
Memory Clock 12-16Gbps 14Gbps 14Gbps 14Gbps 14-15Gbps
Memory
Bandwidth
448-512GBs 448GB/s 448GB/s 448GB/s 190-240GB/s
Cooler Design ? Blower Fan Blower Fan Blower Fan ?
If these rumoured specifications are correct, AMD has set themselves up for a lot of success in late 2019, challenging Nvidia with strong products in all areas of the GPU market. The question now is, when does Nvidia plan to respond with their own post-Turing graphics offerings? Nvidia still has the option to jump to a 7nm lithography node.
You can join the discussion on AMD’s rumoured Navi 12 and Navi 14 graphics cores on the OC3D Forums.
