Far Cry 6’s PC system requirements and features have been revealed
As a cross-generation PC title, Far Cry 6 is designed to run on both last-generation and current-generation console and PC hardware, allowing the game to scale well from low-end PCs to the beefiest of today’s high-end PC rigs.
On PC, Far Cry 6 will support uncapped framerates, a large number of graphical options, multi-monitor and ultra-widescreen setups, DirectX Ray Tracing and AMD’s FidelityFX Super Resolution feature. The game will also include a built-in benchmarking utility.
When looking at the game’s hardware requirements, it is worth noting that Ubisoft has recommended SSD storage to all PC players, highlighting that the gaming industry is quickly shifting to SSD-based storage. It won’t be long before HDDs are too slow to run many modern games, relegating HDDs to long-term game storage, not playback devices.
Far Cry 6 is a DirectX 12 title designed to work on Windows 10 64-bit and newer Windows OS’. Ubisoft has also recommended that Far Cry 6 players use dual-channel memory when playing the game, highlighting that the game will have high bandwidth requirements.
Below are Far Cry 6’s full PC system requirements. Note that these requirements are based on tests performed with AMD’s FidelityFX Super Resolution feature disabled. FidelityFX Super Resolution is a reconstruction technique that can be used to boost the performance of supported titles. This technique should make 4K 60 FPS gameplay achievable on high-end systems and 1440p 60 FPS gameplay a lot more accessible.
MINIMUM PC SETTINGS
1080p, 30 FPS, DirectX Raytracing Off
CPU: AMD Ryzen 3 1200 – 3.1 GHZ or Intel i5-4460 – 3.2 GHZ
GPU: AMD RX 460 – 4 GB or NVIDIA GTX 960 – 4 GB
RAM: 8 GB (Dual-channel mode)
Storage: 60 GB HDD (SSD Recommended)
RECOMMENDED PC SETTINGS
1080p, 60 FPS, DirectX Raytracing Off
CPU: AMD Ryzen 5 3600X – 3.8 GHZ or Intel i7-7700 – 3.6 GHZ
GPU: AMD RX VEGA64 – 8 GB or NVIDIA GTX 1080 – 8 GB
1440p, 60 FPS, DirectX Raytracing Off
CPU: AMD Ryzen 5 3600X – 3.8 GHZ or Intel i7-9700 – 3.6 GHZ
GPU: AMD RX 5700XT – 8 GB or NVIDIA RTX 2070 SUPER – 8 GB
RAM: 16 GB (Dual-channel mode)
Storage: 60 GB HDD (SSD Recommended) 37 GB for HD textures (optional)
1440p, 60 FPS, DirectX Raytracing On
CPU: AMD Ryzen 5 5600X – 3.7 GHZ or Intel i5-10600 – 4.1 GHZ
GPU: AMD RX 6900XT – 16 BG or NVIDIA RTX 3070 – 8 GB
4K, 30 FPS, DirectX Raytracing On
CPU: AMD Ryzen 7 5800X – 3.7 GHZ or Intel i7-10700k – 3.8 GHZ
GPU: AMD RX 6800 – 16 GB or NVIDIA RTX 3080 – 10 GB
Far Cry 6 will feature Ray Traced Hybrid reflections and Ray Traced Shadows on PC. At this time it is unknown how the game’s current-gen (PS5/Xbox Series) console versions will use ray tracing.
You can join the discussion on Far Cry 6’s PC system requirements and PC features on the OC3D Forums.
