Forza Horizon 5 has surprisingly low minimum requirements on PC
On PC, Microsoft has released Forza Horizon 5’s minimum system requirements, which are moderately higher than the system requirements for Forza Horizon 4. When it comes to OS, RAM, storage, and CPU performance, Forza Horizon 5 has identical system requirements to its predecessor. The only change comes in the form of higher GPU recommendations.
With Forza Horizon 5, PC gamers will need GPU performance levels equal to or greater than Nvidia’s GTX 760 or AMD’s RX 460. Both of these GPUs are incredibly low-end by today’s standards but higher-end than the minimum GPUs for the Forza Horizon 4, which were AMD’s R7 250X and Nvidia’s GTX 650 Ti.
Given Forza Horizon 5’s cross-generation nature, the game still needs to run on Microsoft’s baseline Xbox One console. As such, the game needs to support 2013-era Xbox hardware. With that in mind, it makes sense that Forza Horizon 5 can run on such old PC graphics cards and why the game’s CPU requirements are unchanged.
On PC, Forza Horizon 5’s recommended system requirements will likely be higher than the game’s predecessor, thanks to the game’s new graphical feature for Microsoft’s Xbox Series X/S systems. PC gamers can expect new higher-end graphics settings for modern graphics cards and support for DXR ray tracing within the game’s Forzavista mode.
Below are Forza Horizon 5’s minimum system requirements.
MINIMUM:
OS: Windows 10 version 15063.0 or higher
Processor: Intel i3-4170 @ 3.7Ghz OR Intel i5 750 @ 2.67Ghz
Memory: 8 GB RAM
Graphics: NVidia GTX 760 OR AMD RX 460
DirectX: Version 12
Network: Broadband Internet connection
Storage: 80 GB available space
You can join the discussion on Forza Horizon 5’s minimum PC system requirements on the OC3D Forums.
