Gears 5 to receive Technical Test this month – PC system requirements revealed
Gears 5 to recieves Technical Test this month - PC system requirements revealed
On July 19th, Microsoft and The Coalition plans to host a “Gear of War Technical Test” for Gears 5, enabling both Windows 10 and Xbox One users to play through several sections of the game, including the game’s Arcade, Escalation, King of the Hill, Bootcamp and Tour of Duty multiplayer modes.
This technical test will be split between two timeframes, between July 19th and 22nd and between July 26th and 29th. The test will be available to Xbox Game Pass subscribers on PC or Xbox One, though access will also be available to those who pre-order the game digitally or through participating retailers.
This technical test will allow Microsoft to stress test their servers and allow them to test the game over a wide variety of PC hardware configurations, giving the game’s developers access to valuable feedback which could be used to improve the game.
Below are the PC system requirements for Gear 5’s Technical Test, which are expected to be similar to Gear 5’s final PC system requirements. Expect storage requirements to be much higher for the final game, as Gears of War 4 can occupy over 100GB of storage space. More information about the technical test is available here.
Below are Gears 5’s Technical Test PC hardware requirements. These a split between all-AMD and Nvidia+Intel system setups. Sadly The Coalition has not listed these system requirements with resolution or framerate targets.
Minimum Spec (AMD)
Min OS: Windows 10 May 2019 Update
CPU: AMD FX-6000 Series
GPU: AMD Radeon R9 280 or RX 560
VRAM: 2GB
RAM: 6GB
HDD: 15GB
Minimum Spec (Nvidia)
CPU: Intel i3 Skylake
GPU: Nvidia GTX 760 or GTX 1050
VRAM: 2GB
RAM: 6GB
HDD: 15GB
Recommended Spec (AMD)
CPU: AMD Ryzen 3
GPU: AMD Radeon RX 570 or RX 5700
VRAM: 4GB
RAM: 8GB
HDD: 15GB
Recommended Spec (Nvidia)
Intel i5 Skylake
Nvidia GTX 970 or GTX 1660 Ti
VRAM: 4GB
RAM: 8GB
HDD: 15GB
Ideal Spec (AMD)
AMD Ryzen 7
AMD Radeon VII
VRAM: 8GB
RAM: 16GB
HDD: 15GB + SSD
Ideal Spec (Nvidia)
Intel i7 Skylake
Nvidia GTX 2080
VRAM: 8GB
RAM: 16GB
HDD: 15GB + SSD
You can join the discussion on Gear 5’s Technical Test and PC hardware requirements on the OC3D Forums.
