Ghost Recon Wildlands Open Beta and PC system requirements
Ghost Recon: Wildlands Closed Beta PC System requirements
Ubisoft’s Open Beta for Ghost Recon Wildlands will be taking place from February 23-27, here are the game’s final PC system requirements.
The game’s open beta will require 50GB of hard drive space and a minimum of either a GTX 660 or an R9 270 GPU, with the game requiring at least 2GB of VRAM and 6GB of system memory.
While the game recommends four CPU cores, with either an Intel i5 2400S or an AMD FX 4320, though it is expected that the game will run well on a modern Intel i3 (with 2 cores four 4 threads) or a Kaby Lake series Pentium, which are the first Pentium CPUs to feature hyperthreading.
The content of this new open beta will be the same as the previous closed beta, though this new beta version will as add new province called Montuyoc, which contains a few heavily defended strongholds.
   If you didn’t get a chance to participate in the Ghost Recon Wildlands Closed Beta, we’ve got some good news! The Ghost Recon Wildlands Open Beta starts February 23 (with preloading available February 21), giving you an opportunity to squad up with the Ghosts and get a preview of what it will be like to take on the Santa Blanca drug cartel on PS4, Xbox One, and PC.
Running through February 27, this Open Beta features all of the same content found in the Closed Beta and more, including an additional province to explore called Montuyoc. Set in the Bolivian Altiplano region, this province contains heavily defended strongholds where the Santa Blanca trains some of its toughest soldiers.
PC specs and system requirements for the Ghost Recon Wildlands Open Beta and final release can be found below. You can have a look at our Ghost Recon Wildlands Closed Beta performance here.
MINIMUM:
OS: Windows 7 SP1, Windows 8.1, Windows 10 (64-bit versions only)
PROCESSOR: Intel Core i5-2400S @ 2.5 GHz or AMD FX-4320 @ 4 GHz or equivalent
VIDEO CARD: NVIDIA GeForce GTX 660/GTX 750Ti/GTX 950/GTX 1050 or AMD HD 7870/R9 270X/R9 370X/RX 460 (2GB VRAM with Shader Model 5.0 or better) – See supported List */**
SYSTEM RAM: 6GB
Resolution: 720p
Video Preset: Low
RECOMMENDED
PROCESSOR: Intel Core i7-3770 @ 3.5 GHz or AMD FX-8350 @ 4 GHz
VIDEO CARD: NVIDIA GeForce GTX 970/GTX 1060 or AMD R9 290X/R9 390/RX 480 (4GB VRAM with Shader Model 5.0 or better) – See supported List */**
SYSTEM RAM: 8GB
Resolution: 1080p
Video Preset: High
*Supported NVIDIA cards at time of release:
• GeForce GTX600 series: (minimum) GeForce GTX 660 or better | (recommended) N/A
• GeForce GTX700 series: (minimum) GeForce GTX 750Ti or better | (recommended) N/A
• GeForce GTX900 series: (minimum) GeForce GTX 950 or better | (recommended) GeForce GTX 970 or better
• GeForce GTX10-Series: (minimum) any GeForce GTX 10 card | (recommended) GeForce GTX 1060 or better
**Supported AMD cards at time of release:
• Radeon HD7000 series: (minimum) Radeon HD 7870 or better | (recommended) none
• Radeon 200 series: (minimum) Radeon R9 270x or better | (recommended) Radeon R9 290X or better
• Radeon 300/Fury X series: (minimum) Radeon R9 370X or better | (recommended) Radeon R9 390 or better
• Radeon 400 series: (minimum) Radeon RX 460 or better | (recommended) Radeon RX 480 or better
Gamepad Support
• Microsoft Xbox 360
• Microsoft Xbox One (Original/Elite)
• PlayStation 4 (Original/Pro)
• Steam controller
Other controllers may work, however. they are not officially supported. They may require third-party software to work. Please contact the controller manufacturer for assistance. Examples include:
• Any third-party Xbox-compatible controller
• Logitech Chillstream
• OUYA controller
Ghost Recon Wildlands’ Open Beta will be available to play from February 23rd until February 27th. The full game will release on March 7th on PC, PS4 and Xbox One.
You can join the discussion on Ghost Recon Wildlands’ PC system requirements and Open Beta on the OC3D Forums.
