How to adjust Prey’s FoV and disable Motion Blur
How to adjust Prey’s FOV and disable Motion Blur
To edit Prey’s FoV and motion blur settings you will need to navigate to C:Users(YourUserName)Saved GamesArkane Studios on your PC and open a file called game.cfg. Inside this file, you can edit a setting called cl_hfov = 85.5656, which will allow users to edit the game’s FoV.
Below is an example edit that will change your FoV to 120 degrees.
cl_hfov = 120
To disable motion blur, you must add a new line to this document which is called r_motionblur = 0 which will remove the game’s default Motion Blur option.
Arkane Studios has already stated that the game will be getting an official FoV slider in a future patch, though for now, users will have to use this workaround.
You can join the discussion on Prey’s FoV options on the OC3D Forums.
