How to skip Borderlands 3’s Intro Videos and Spashs Screens – Reduce Initial Load Times
In Borderlands 3, it is easy to skip the 2K, Gearbox and AMD splash screens that are featured in every game bootup. All you need to do is this. Navigate into the Borderlands 3’s game files and either delete or rename the videos in question. Simple. That’s what this short article is all about.
Finding Borderlands 3’s Folder
By Default, the Epic Games Store will download Borderlands 3 to the following directory. This directory will change depending on which storefront you purchase Borderlands 3 from, and depending on whether or not you have chosen to install the game elsewhere on your system.
C:ProgramFilesEpicGamesBorderlands3
Where are the Intro Video Files
Borderlands 3’s Splash Screen videos are available within the following folder. Enter into this folder and either delete or rename the following videos; 2KLOGO.mp4, AMDLOGO.mp4 and GBXLOGO.mp4.
Doing this will prevent these logos from appearing every time you boot Borderlands 3. Please note that game updates may restore these files, requiring players to delete or edit them again.
[Path To Game]Borderlands3OakGameContentMovies
Save File Locations
Below is the location of Borderlands 3’s save files. Use this to make copies of your save files if needed, or to delete them if you find it necessary.
%USERPROFILE%DocumentsMy GamesBorderlands 3SavedSaveGames
Expect to see a full PC Performance Analysis of Borderlands 3 in the coming days.
Update – Our full PC performance review and Optimisation Guide for Borderlands 3 can be read here.
You can join the discussion on Borderlands 3 on the OC3D Forums.
