Published: 13 January 2017 |
Source:
Steam |
Author:
Styx: Shards of Darkness PC system requirements
The PC system requirements for Styx: Shadow of Darkness, the Unreal Engine 4 stealth-based assassination game, have been released, revealing some high CPU and memory requirements alongside more moderate GPU requirements.
On the AMD-side the developers recommend an AMD 8-core Piledriver CPU or higher, or an Intel Broadwell i5 at 3.1GHz or above. The game will require 8GB of system memory and an R7 370 or GTX 570 GPU or above.
The game itself looks graphically impressive, suggesting that the game will require much higher-end hardware on the GPU side when played at higher graphical settings.
Below are the game’s minimum system requirements, with the game having no listed recommended PC hardware configuration.
MINIMUM:
- OS: Windows 7 (64-bit)
- Processor: AMD FX-8320 (3,5GHz) / Intel i5-5675 (3,1GHz)
- Memory: 8 GB RAM
- Graphics: AMD Radeon R7 370 / Nvidia Geforce GTX 570
- Additional Notes: Online connection for Co-op Play
Styx: Shard of Darkness will release on PC on March 14th.
You can join the discussion on Styx: Shards of Darkness on the OC3D Forums.
MINIMUM:
- Memory: 8 GB RAM
