Corsair Void RGB Elite Wireless Review
Software
As you would expect from a Corsair product the Void Elite has plenty of lighting options including the ability to copy the other lighting settings on your Corsair products. The equaliser has five built in presets but you can easily build your own either using linked sliders for a smoother graduation of tones or individual ones to boost or cut that stubborn frequency. Thankfully the default sound is spot on so you wont need to tweak other than personal preference. Lastly you can shut up the woman who tells you when you’ve swapped from 7.1 to stereo mode before she drives you crazy.
