A Worthy Flagship – ASUS ROG Cronox GR801 ARGB PC Case Review
A proper flagship-level case for ROG enthusiasts
This is a true flagship-level PC case for the ASUS ROG brand. Its large bent tempered glass panel, reinforced liquid polymer crystal (LCP) fans, and large LCD screen signal that this is the best case ASUS ROG can currently produce. This PC case is large, imposing, and well built. The only exception is the included vertical GPU mount, which lacks rear GPU support and is a bit wobbly. However, this is only a problem for users who are moving the case. Moving the case with a GPU in this mount will likely move the GPU itself.
The ROG Cronox is the ultimate ASUS ROG PC case, and if that is what you want, this is the case for you. Its LCD screen, aluminium-trimmed exterior, ROG lighting panel, and ambient lighting make this case look and feel premium.
There’s very little to criticise about this case
We have to get really nitpicky to properly criticise the ROG Cronox. For our system, we needed to use three different software programs to control the case’s LCD screen, its ROG Eurux fans, and the screen on our ROG RYUO IV 360 ARGB liquid cooler. That’s a lot of software, and ASUS should tackle that if they want a more coherent hardware/software ecosystem.
Aside from the visible cables with the ROG Strix XIN120 ARGB lighting panel, the many softwares we needed, and the relatively flimsy vertical GPU mount, this case is nearly perfect. Well, perfect for ROG fans. Would you honestly dream of putting non-ROG hardware inside this? Well, I guess you could, but something feels wrong about that.
Much better value than older ROG flagship-level PC cases
Pricing is always a problem with PC cases like this. £499.99 is a lot of money, especially when users will likely need to buy more fans in addition to what’s included. That said, we remember the launch prices of cases like the ROG Hyperion and ROG Helios II, and for its money, the ROG Cronox offers more than its predecessors. ASUS’ included Eurux GR120 fans are a clear step up from the fans that ASUS previously used. Additionally, ASUS has included an LCD screen and a neat ROG lighting panel. These add-ons do a lot to make this case feel both modern and ROG.
This case is worthy of the high-end components that ASUS’ ROG brand prides itself on. There are reasons to like this case beyond its branding. It gets most of its little details right, and it is a PC case that is enjoyable to build with. For that reason, the ROG Cronox deserves the rare OC3D TTL Approved Award. If you want to know more about why this case deserves it, just watch our video review.
Join the discussion on our ASUS ROG Cronox ARGB GR801 PC case review on the OC3D Forums.
