Cooler Master’s MasterAir MA620M CPU cooler – A Mini Wraith Ripper?
Up Close and Build
If there is one thing that the MasterAir MA620M oozes its class. It’s stealthy black finstack, and hidden fan design separates the MA620M from traditional CPU cooler designs, lacking the utilitarian looks of Cooler Master’s other models.
The MA620M is designed to look good within your system, offering an appealing aesthetic which will please both professional users and RGB enthusiasts alike.
With the MA620M, Cooler Master has hidden the unit’s fan in-between the cooler’s two fin stacks, presenting users a CPU cooler that appears to be fanless. The black aspects of this cooler grants the MA620M a monolithic appearance, making the cooler well suited to slrealthy all-black PC builds, as well as RGB lit rainbow-rigs.
Heatsink installation is a breeze, requiring users to install the mounting kit and then to tighten two screws after some thermal compound is applied to your processor. Tighten two Philips head screws evenly and the cooler is installed. It doesn’t get any simpler than that.
Connect the ARGB LEDs to your system and you are got to go when it comes to custom RGB lighting. It’s almost too easy.
