Raijintek Agos Review
If there’s an area of the PC case market that’s more cut throat than the others, it is without doubt the budget case sector. It’s here that the assembled hordes of massed PC cases vie for your attention, with only a few standing out above the crowd to the illuminated as a case worthy of expending their hard earned dosh on. Get it right and you can get quite a lot for £40. Get it wrong and you can end up with a proper Lemon. Looks of course as important here as in any area, but so too is functionality and quality. It’s into this Melee that Raijintek pitch the Agos. Available in both Black and white and touting more HDD bays than you can shake a stick at, as well as a trio of 5.25 bays it does at least seem that there’s a lot of potential to be had here. For the full skinny, best we take a gander at the Technical Specification
| Dimensions | 200x460x490mm (WxHxD) |
| Weight | 5.9kg |
| Material | SPCC 0.55mm and Plastic |
| Colour | White or Black |
| Motherboard Support | ATX, M-ATX |
| 3.5″ | 6 |
| 2.5″ | 6 (shared with 3.5″ |
| 5.25″ | 3 |
| Expansion Slots | 7 |
| Front I/O | 1xUSB3.0 1xUSB2.0 HD Audio |
| PSU | ATX PS/2 not included |
| Cooling |
Front: 2x120mm, 1 included Rear: 1x120mm included Roof: 2x120mm or 2x140mm Base: 1x120mm Side Panel: 2x120mm or 2x140mm |
Key Features
Elegant and classic design with efficient and massive airflow
Removable 3.5″HDD cage, provides enthusiasts more convenient installation and opportunities
Special Automotive Intake Air Design for Superior Airflow
Enlarged front mesh
USB 3.0 super speed port (internal)
Whole black coated and white coated interior
Dust-Control filters for all mesh area
Accommodate an internal 240 mm radiator at the top
Rear tubing holes for water cooling
Supports 160mm height cooler, RAIJINTEK all coolers except NEMESIS
Supports up to six fans(two 140mm and four 120mm) and six HDD(3.5″ or 2.5″)
Tool-free system for ODDs and HDDs
Supports VGA card up 410mm(remove HDD cage) and CPU cooler up to 165mm
