Sapphire Nitro+ B850M WiFi Motherboard Review
Sapphire are generally more famous for their graphics cards than their motherboards. However, one thing that has remained a constant is their commitment to the AMD technologies. Whether it’s Radeon graphics or an AMx socket, Sapphire have a model for everyone.
At the top end of the Sapphire range are their Nitro+ offerings. We recently built a Nitro+ system using their BTF “Phantom Link” technology. You can read about that here. Should you have had your curiosity piqued, but would prefer to stick with a regular setup, today’s review of their Nitro+ B850M motherboard will be just what you’re after. Especially if, like so many people, you’ve had your head turned by the AMD Ryzen X3D processors.
X3D give a game performance boost for free, and this is particularly effective on medium performance setups. Obviously you can gain frames at 4K on a RTX 5090, but the biggest gains are things like a RX 9060 XT @ 1440P. Maximising your value for money is the cornerstone of such systems. It’s where even slight differences can have a massive effect. Anyone can throw money at a problem. A carefully chosen setup that fits within budget whilst still making you smile is one of life’s joys.
With a sub-£140 price tag, the Sapphire Nitro+ B850M WiFi supports all AM5 Ryzen processors, plenty of memory, still has PCIe Gen5 slots and storage support, and doesn’t scrimp on the USB ports either. It might well be the best kept secret in AMD based motherboards. Let’s put it to the test.
