All White RTX System With Gigabyte Vision
Test Setup
Gigabyte RTX 3070 Ti Vision – £708.99
Gigabyte RTX 3080 Vision – £949.99
Gigabyte RTX 3080 Ti Vision – £1399.99
Ryzen 9 5900X
Gigabyte B550 Vision
32GB Corsair Vengeance Pro SL
Corsair H150i Cappilex White
Corsair MP600 2TB NVMe M.2 Gen4
Corsair CX750F RGB PSU
Corsair 5000X White Case
PCI Express 4.0 Riser cable for vertical mounting
Windows 10 x64 “May 2020” UpdateGigabyte RTX 3070 Ti Vision
Affiliate links if you are interested:
Final Build
This is why we were explaining the importance of components which fit together well. By going with just Corsair components for the case and cooling, with Gigabyte Vision providing the motherboard and GPUs, you get a setup which looks custom made.
With multi zone RGB lighting you can do anything you want, but naturally we went with the OC3D theme of white with red accents. It’s classy and also demonstrates the flexibility of the Corsair lighting system.
The PCI Express 4.0 riser works perfectly positioning our Vision GPU without limiting the performance. Impressive for the money.
If you were allergic to red, or just wanted to go for a very ‘all white’ look then obviously you can do that too. Or really go mental and have a white system with just coloured lighting. It’s all possible.
