Roccat Isku Keyboard Review
Software
As with all good Macro software the Isku comes with a wealth of preconfigured options for the most popular titles. Although your game of choice might not be listed, there are two things to keep note of. Firstly a lot of games have very similar control schemes, so what works in Modern Warfare 2 is likely to work in many other FPS games. Secondly creating macros is very simple. Just press the Live Macro record button and type. You can then delete individual elements too, so if you accidentally catch something else amongst a hugely complex string, you aren’t forced to start afresh.
However, because using Live Record also records all the delays and the like of your typing, so if you want more exacting control you can go into the advanced editor and fine tune things within a millisecond of their life. The potential is exhaustive.
