Grand Theft Auto VI PS5 Review
Oh The Places You’ll Go
The map is huge. Loads of things. It’s more detailed, and more in depth than you can imagine. Any worries we had regarding the minimap when watching the Netflix reveal are also out the window. Apart from the multi-lane highways, which can sometimes require an exit faster than the GPS can tell you. This shot is just a small bit, but you can go everywhere in the foreground, and there is something to see. It’s not just empty procedurally filled nothing. Additionally the city spreads far away, and is bigger than it looks even here.
Annoying there isn’t a “ highlight everything” option. Want to know what’s nearby? Too bad. Even holding your cursor over a spot on the map that you know has something, doesn’t bring up a “this is what is here” popup. Your only choice is to open the map, pick which one of the 9 [nine] main menus are your thing.
Having done that there are sub menus. Oh boy are there sub menus. Right now each of those nine has, respectively, 6, 8, 9, 11, 9, 9, 5, 9, 6 further sub menus. With the 3rd and 4th one of those have umpteen further sub menus. The “activity” (weights) is split between gyms and the dozens of sidequests. Want to know the nearest Pay N Spray? Well thankfully it automatically opens to the nearest one, but if that falls within zone of police awareness, you might need a different one. Or maybe you just want to drive to one that will clear some fog of war. Be prepared to spend a LOT of time looking at this view.
