PCSpecialist Zircon Elite R Review
Clock and Storage Speeds
If you’re a regular reader or seeker of great value hardware then a lot of this will be very familiar. We’ve only just looked at length at the new RDNA4 RX 9070 AMD card. The Ryzen 5 9600X has found a home in huge quantities of systems thanks to its solid all-round performance credentials. Meanwhile the Solidigm P41 M.2 strikes a great price/performance balance. At only 1TB you’ll need to do some juggling if you have a massive game library. But, as we said about the case, PCS let you customise the build to taste, so you can get more if you will need it.
