BitFenix Spectre Pro Range Review
Relative new comers BitFenix have made a massive impact since their arrival on the scene back in April of 2010,  Along with their Colossus case one of their first products to market in August of the same year was the now well recognised “Spectre” series of fans.  The original Spectre (which is still widely available) is recognised for it’s quiet operation and it’s selection of LED colour options.  Since then BitFenix have gone from strength to strength releasing a not insubstantial range of cases, and of course their delectable “Alchemy” braided cables.  Already recognised for the high quality of their products and for supporting their customers (the  official UK support forum is housed on this very site), BitFenix have a reputation for Listening to, and acting upon the feedback they receive. With that Spirit of listening to feedback in mind BitFenix have revisited the Spectre range, releasing the “Spectre Pro”
Specifications
In this review I shall be looking at the entire Pro range, using examples from each of the sizes for illustrative purposes. To keep things from getting too messy  I have grouped the Tech-Spec for the whole range together on one page, providing an “at a glance” appraisal of their capabilities, although as I go through the review I’ll be comparing the specs of the original fans to those of the new.  Below I’ve listed the Specs for the new LED fans, but the new non LED share exactly the same set of figures.
Spectre Pro™ LED
Materials
PC & PBT
Operating Voltage
12VDC
Starting Voltage
5VDC
Bearing Type
Fluid Dynamic Bearings (FDB)
120mm
Dimensions (mm)
120x120x25mm
Current (A)
0.18A ±10%
Speed (RPM)
1200 RPM ±10%
Air Flow (CFM)
56.22 CFM ±10%
Air Pressure (mmH2O)
1.24 mmH2O
Noise (dB-A)
18.9 dB(A)
140mm
Dimensions (mm)
140x140x25mm
Current (A)
0.25A ±10%
Speed (RPM)
1200 RPM ±10%
Air Flow (CFM)
86.73 CFM ±10%
1.38 mmH2O
Noise (dB-A)
22.8 dB(A)
200mm
Dimensions (mm)
200x200x25mm
Current (A)
0.33A ±10%
Speed (RPM)
900 RPM ±10%
Air Flow (CFM)
148.72 CFM ±10%
1.26 mmH2O
Noise (dB-A)
27.5 dB(A)
230mm
Dimensions (mm)
230x200x30mm
Current (A)
0.41A ±10%
Speed (RPM)
900 RPM ±10%
Air Flow (CFM)
156.27 CFM ±10%
