Prolima Tech Vortex Fan Review Round Up
 Prolima Tech Vortex fans
It’s no coincidence that ProlimaTech, well known for their range of performance CPU and VGA cooling solutions, should also produce a range of fans.  Here we take a look at the entire Vortex range,  including the rather sexy looking Aluminium bladed 140mm model.   With the exception of the Aluminium model which comes fitted with red LEDs as standard, ProlimaTech offer 2 sizes and 3  finishes to the range, with both the 120mm and 140mm fans available in plain red, plain blue, LED red and LED blue.  On paper the fans offer high CFMs with varying dB-A ratings.  Lets look at the full tech spec for a better idea of what we have on offer to us.
Specifications
120 Vortex
Dimension
(L)120mm X (W)120mmX (H)25mm
Bearing Type
Sleeve bearing
Rated Voltage
12 VDC / 9 VDC
Operating Voltage Range
6~13.8 VDC
Rated Current
0.18 Max.Amp
Rated Power
2.16 Max.Watt
Rated Speed
1600 RPM / 1200 RPM
Airflow
72.67 Max.CFM
Noise Level
29.1 dBA
Net Weight
138.2 Gram
Connector
Terminal Connector(3-pin plus 4-pin molex)
120 Vortex LED
Dimension
Bearing Type
Sleeve bearing
Rated Voltage
12 VDC / 9 VDC
6~13.8 VDC
Rated Current
0.3 Max.Amp
Rated Power
3.6 Max.Watt
Rated Speed
1600 RPM / 1200 RPM
Airflow
72.67 Max.CFM
Noise Level
29.1 dBA
Net Weight
107.2 Gram
Connector
LED
Blue/red
140 Vortex
Dimension
(L)140mm X (W)140mmX (H)25mm
Bearing Type
Sleeve bearing
Rated Voltage
12 VDC
7~13.8 VDC
Rated Current
0.2 Max.Amp
Rated Power
2.4 Max.Watt
Rated Speed
1000±100RPM
Airflow
87 Max.CFM
Noise Level
18.1 dBA
Net Weight
162 Gram
Connector
140 Vortex LED
Dimension
Bearing Type
Sleeve bearing
Rated Voltage
12 VDC
7~13.8 VDC
Rated Current
0.2 Max.Amp
Rated Power
2.4 Max.Watt
Rated Speed
1000±100RPM
Airflow
87 Max.CFM
Noise Level
18.1 dBA
Net Weight
162 Gram
Connector
LED
Red/Blue
140 Aluminium
Dimension
Bearing Type
Two Ball bearing
Rated Voltage
12 VDC
7~13.8 VDC
Rated Current
0.45A
Rated Input Power
5.4W
Rated Speed
1600RPM/1200RPM/900RPM
Airflow
127CFM/100CFM/65CFM
Noise Level
28dBA/20dBA/15dBA
Net Weight
152g
LED
Red
Accessories
Fan Screw*4 3;4-Pin Adapter*1,
Low Rotation Adapter*2
