ASUS GTX560Ti 448 Core DirectCU II Review
Despite being a limited product and only available in certain countries, including the UK, the 448 Core version of the nVidia GTX560Ti has divided opinion between those who like the cheeky bit of extra power available when compared to the standard GTX560Ti, and those who think it's expensive enough to be pointless, considering the GTX570 is only about a tenner more.
So with the ASUS GTX560Ti 448 DirectCU II in our sweaty palms, let's see if this can help clarify things a bit. Although the main point from that immense title is that nVidia should have called it the GTX565 if only to save us all needing widescreen monitors to read the product name.
Apart from the DirectCU II cooler, the ASUS version is identical to the stock option, with the standard 732MHz core. Hopefully the excellent cooler will allow us to romp towards 1GHz.
Graphics EngineNVIDIA GeForce GTX 560 Ti 448 cores
Bus StandardPCI Express 2.0
Video MemoryGDDR5 1280MB
Engine Clock732 MHz
CUDA Core448
Shader Clock1464 MHz
Memory Clock3800 MHz ( GDDR5 )
Memory Interface320-bit
ResolutionD-Sub Max Resolution : 2048x1536
DVI Max Resolution : 2560x1600
InterfaceD-Sub Output : Yes x 1 (via DVI to D-Sub adaptor x 1)
DVI Output : Yes x 2 (DVI-I)
HDMI Output : Yes x 1
Display Port : Yes x 1 (Regular DP)
HDCP Support : Yes
Accessories1 x Extended SLI cable
1 x Power cable
1 x DVI to D-Sub adaptor
SoftwareASUS Utilities & Driver
ASUS FeaturesDirectCU Series
Super Alloy Power
Dimensions11.1 " x 4.9 " x 2.3 " Inch
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
12-12-2011, 05:05:26
ASUS have released their version of the GTX560Ti with 448 Cores, and equipped it with the DirectCU II cooler.
Continue ReadingQuote
12-12-2011, 18:39:14
Thanks Tom for another great review. Seems like Asus is really big on these bulky coolers. I would still very much prefer MSI and Gigabyte's coolers for performance/silence and that they save a bit more space for parts and upgrades. Quote
12-12-2011, 19:24:35
I do like the DCUII cooler they keep my gtx 580's in lineQuote
