Gainward Phantom GTX570 Review
Search Reviews
The GTX570 has been one of the big surprises of recent times, fixing all the issues of the original Fermi nVidia cards and performing incredibly well for the reasonable price charged. With a good chip you can expect to overclock it up to stock GTX580 speeds.
Unquestionably it's the card we'd recommend as the major player on the market at the moment.
Gainward have been producing graphics cards for a very long time. Indeed your authors first upgrade after the Voodoo 2 and Riva TNT days was to a Gainward model.
The most famous of the Gainward series is unquestionably the Golden Sample labelled cards which come with a good factory overclock and always managed to go further still.
Today however we have a new model from them labelled the Phantom. The surprise being that rather than concentrate on pushing the Silicon as hard as possible they've brought us a very different looking cooling solution indeed and only overclocked the GPU mildly.
A quick look at the specifications shows that the apart from the 18MHz GPU overclock the Gainward Phantom is very much a standard card.
Product Name  :    Gainward GeForce® GTX 570 1280MB "Phantom"
GPU  :    GeForce GTX 570
GPU Clockspeed  :    750 Mhz
Memory  :    1280MB GDDR5 (320 bits)
Memory Clockspeed  :    1950 Mhz
Pixels per clock (peak)  :    N/A
Bandwidth  :    156 GB/s
Ramdac  :    400 MHz
Bus  :    PCI-Express 2.0
Cooling  :    2.5-Slot/Three Fans cooler
Video-Features  :    HDMI
Connectivity  :    Dual DVI-I, DisplayPort
Of course the cooler is the real selling point of this, so let's move on and take a look at that.
«Prev 1 2 3 4 5 6 7 8 Next»
17-01-2011, 04:06:14
tinytomlogan
The first non-reference design GTX570 comes from the always busy Gainward. Is the Phantom a big improvement or just an illusion?
Continue Reading
17-01-2011, 04:18:36
Hribi
I won't one the look is ossom.
17-01-2011, 04:33:07
SnW
That's some proper cooling its lets say ossom
nice review again Bryan
17-01-2011, 04:35:57
Black
What setting did you use Tom on Metro 2033?
17-01-2011, 05:23:12
henrybutt
Is it just me or was this designed specifically to match the Gigabyte P67A-UD7... they would look so sexy together
17-01-2011, 06:30:49
Morbious Stone
Man That card is quite sexy, Great review I was laughing Most of it! Gainward needs 2 start selling in the US lolz
17-01-2011, 06:33:06
Zeals
Now that is one fine looking card, shame it takes up 3 PCI slots, so I don't think you'll be able to run it in 16x/16x SLI on the UD-7.
17-01-2011, 06:41:12
tinytomlogan
You wont because the UD7 is normal ATX 2 slot for multiples.
17-01-2011, 07:11:09
adicool96
What does bryan mean by less standard ways of increasing the voltage? Does it work for the gtx580
17-01-2011, 07:13:56
tinytomlogan
Some cards dont have Voltage tweaks enabled in the back end bios of the cards, but there are ways around it. We dont normally touch these in reviews but both thought we would find out how far the card would go if we did.
17-01-2011, 08:47:55
Zeals
What do the fans sound like when you crank them to 100%? Even though you probably wouldn't need to, but some of us might live in warmer climates and with global warming you never know .
17-01-2011, 09:04:58
adicool96
How do you bypass that? Maybe you could make a guide or something?
17-01-2011, 11:12:36
Todd
Google is your friend. Other than that.. stonking good looking card. Nice review from both of you guys. BTW: Play the vid at 14:40 to 14:48
Anyway, good looking card but the performance is somewhat disappointing. I had higher hopes for the 570 considering its price.
17-01-2011, 12:25:57
I Hunta x
Any idea when the rough ETA for this card is?
Would make a tastey silent addition to the D14 i have on the way.
17-01-2011, 12:44:31
Bungral
The conclusion says it was a bit nip and tuck between it and the ref 570... Well from what I was reading it frequently lost out to the reference model which it has absolutely no reason to do especially with it's factory overclock.. It's small but none the less there and should be beating the ref in every test.
If this card ends up costing much more than the ref model then there is no point in buying it.. Your card will run cooler but will dump all the hot air in to your case. The card looks good, but when installed, all you can see through a window is the black edge and Gold Gainward name.
With no voltage tweakage allowed by the bios and no meaningful factory overclock this card seems a bit poo to me.
People go on about waiting for the non ref designs for cooler cards to allow a little more overclocking headroom but this doesn't offer anything like that and clocks less than the ref card for what I expect will be a price premium. It might be quieter, but my 570 runs as good as silent.. My PSU is louder.
Unimpressed.
Good review as always guys.. Just a shame Gainward didn't put a better version of the bios on the card with higher clocks and some voltage allowance.
Edit: Just finished watching the video.. I'll take some of that back as if you can edit it in the beta of Afterburner then that's just as easy as opening any other software to do it.
Out of curiosity, what was the max Afterburner allowed on the voltage? 1.1v?
17-01-2011, 14:12:54
timby
So it begs the question The GTX570 or the ATI 6970?
Inquiring minds want to know......
17-01-2011, 16:34:54
murphy7801
This does give me high hopes for the gainward GLH gtx 570
17-01-2011, 16:51:30
Bungral
Still the 570
17-01-2011, 17:06:50
murphy7801
You can also remove the price TBC
http://www.lambda-tek.com/componentshop/index.pl?origin=gbase17.5&prodID=B566551
unless this is a lie which it could be.
17-01-2011, 18:32:42
Delusion77
looks really nice
17-01-2011, 19:56:36
murphy7801
Originally Posted by Delusion77 View Post
looks really nice
I would like see a bios update bit think take its more steroid hungry smaller brother the ghl.
17-01-2011, 20:47:09
Zeals
If you're going to go with two cards or more 6970, since it scales better. But for just a single card 570 all the way.
17-01-2011, 21:34:06
murphy7801
Actually what test I can find they scale about the same
18-01-2011, 05:55:10
Bungral
Wouldn't necessarily trust them as they always seems to quote low to get the traffic through Google shopping searches then when you click check stock, they are 80% of the time out of stock.
18-01-2011, 19:32:35
Filekutter
Ummm TTL, I've never seen you drooling so hard... mebbe you should play Crysis BEFORE you strip sexy cards..? You owe me a KB by the way.. ROFLMAO!
24-01-2011, 10:15:50
murphy7801
Its now on scan.co.uk for £305
24-01-2011, 13:41:00
Bungral
Ahh fair enough.. £30 premium for the cooler which isn't bad I guess if it actually helped.
24-01-2011, 16:27:02
murphy7801
Yer the gtx 570 gainward GS-GLH is more at around £320 which leads me to think that there something else making it expensive like cherry picked cores or something.
09-02-2011, 14:55:18
PurpleTrance
I have one of these. It's alright, unlocking voltages can be done with the new afterburner beta.
3gb 580 version looks like a beast
13-02-2011, 11:22:38
TuNk77
I have this card and I'm fairly happy with it, 36c idle, 64c load, nice temps. The fan is nearly silent up to 50%
On 100% fan speed, it sounds like an hair dryer
13-02-2011, 11:26:47
murphy7801
Indeed think it with have enough memory for any screen size.
