Alphacool launches their Mining Rig 12 Open Air GPU Mining Frame
Alphacool launches 12 GPU Open Air Mining Frame
Alphacool has launched their first official MIning Rig series product, the Mining Rig 12 Open Air Frame, a custom mining rack which can support up to 12 GPUs, two motherboards, and four PSUs.
Being a water cooling focused company Alphacool has also kitted out their frames with support for up to six 360mm water cooling radiators, allowing users to water cool all 12 GPUs connected to the system. While this may seem silly to some, many GPUs are more efficient under water cooling, and the reduced thermal stress on the mining hardware may increase the lifespan of each mining card in the system.
The Mining Rig 12 has also been designed stacked on top of each other using a screw mount system to securely place large collections of mining hardware in a single location while offering enough open space to replace faulty equipment or upgrade mining systems quickly.
Alphacool has integrated seven fan mounting locations across the chassis, directing airflow around each of the system’s GPUs and the system’s power supplies, ensuring that each component receives optimal airflow and that GPU performance will not suffer due to thermal constraints.
While many of you will have your own opinions about GPU mining, it is undeniable that Alphacool has created an incredibly functional mining frame, keeping GPU equally spaced while providing mounts that will suit almost any mining configuration. The only problem that we can foresee is reduced demand from miners, given recent drops in GPU demand and pricing.
Alphacool’s Mining Rig 12 is available for €148.79 on the Alphacool web store.
You can join the discussion on Alpahcool’s Mining Rig 12 water-cooling ready mining frame on the OC3D Forums.
